-   -   Durarock (http://www.diychatroom.com/f2/durarock-4750/)
econdave 11-11-2006 08:35 AM
Durarock
do you use drywall screws to install this stuff? thanks
tkle 11-11-2006 09:50 AM
I use decking screws.They'll hold more weight and don't rust.
dougrus 11-11-2006 11:52 AM
There are screws designed for cementboard installation. I have used the "Rock-On" band and they work really well. They are similar to decking screws...Whatever you do, dont use drywall screws.
Bonus 11-11-2006 03:05 PM
The ONLY thing drywall screws are good for is drywall.
econdave 11-11-2006 05:49 PM
do you have to pre-drill this stuff?
AtlanticWBConst. 11-11-2006 06:02 PM
They are laminated screws. They have a protective coating on them to resist corrosion and to 'slide' through the cementious material of the board. The design of the head also does a better job at 'grabbing' the board and pulling it tight to the framing members.
As mentioned already, there is a manufacturer that makes 'Rock On' - "Cement Board Screws". Most Drywall suppliers carry them. I also know that HD carries them.
No, no pre-drilling required...
