Dumpster Size For A House Remodel? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-17-2007, 10:33 AM   #1
Exclamation
Dumpster size for a house remodel?
We are tearing out all carpet and linoleum, a tiled bathroom and shower, and just general trash and old paint, wood, etc left behind by the previous owners in a 2800 sq ft house. Do we need a 30 or a 20 size dumpster? Thank you!
ashley is offline   Reply With Quote
Old 08-17-2007, 08:53 PM   #2
Not likely. I'm thinking more like 6' by 20'. Of course bigger is often (offen) easier but I've work BIG commercial construction jobs that don't use dumpsters THAT BIG!
shotdown is offline   Reply With Quote
Old 08-19-2007, 07:58 PM   #3
Builder/Remodeler
ChrWright's Avatar
I have to disagree.
Go for the 20... You will fill it easily. Be sure you roll the carpet as you take it out--it will take up less space.
ChrWright is offline   Reply With Quote
Old 08-19-2007, 09:34 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
1) No way to tell from here
2) You'll find more stuff to throw in there if it's there
3) Your neighbors will find stuff to throw in there
4) Your relatives will find stuff to throw in there
Get the 30
slickshift is offline   Reply With Quote
Old 08-19-2007, 10:07 PM   #5
robertcdf's Avatar
I always get a 30... unless I know I only need 10 then I get a 20.
robertcdf is offline   Reply With Quote
Old 08-20-2007, 05:10 PM   #6
Mod / ArchiBuilder
Cole's Avatar
Get the 30
I couldn't agree more.
Cole is offline   Reply With Quote
Old 08-20-2007, 05:38 PM   #7
weekend warrior
Rewards Points: 150
The difference in cost between sizes is nothin' compared to the cost of getting a 2nd container!
I paid $30 to bump up from a 15yd to 20yd and should have gone even bigger.
Among other things, you wont have to be worried about packing everything so nice and tight in there...
johnny331 is offline   Reply With Quote
Old 08-20-2007, 07:07 PM   #8
Check in your area but most Dumpster Companies will charge an arm and a leg if you throw paint in (It's considered Hazardous waste). Your best bet is to go to a local recycle place with the paint.
As far as size a 20Yrd should be more than big enough.
jiggyjack is offline   Reply With Quote
Old 08-20-2007, 09:30 PM   #9
Custom Cabinet Maker
only cost me 100 bucks to go from 10 to 20. Here not cheap tho, with a break 460 bucks for 20
skymaster is offline   Reply With Quote
Old 08-20-2007, 11:47 PM   #10
Rewards Points: 5,336
Get the biggest one they have. Better to over estimate if this is a mysterious calculation.
Ron
Old 12-31-2008, 09:03 PM   #11
Dumpster Rental answers
As far as sizes go, I would try going to www.domesticdumpsters.com. They have a FAQ section that helps to select the correct dumpster size. Also, don't forget about getting a permit for the dumpster. Most municipalities require the homeowner to obtain a permit before the roll off container is delivered. DomesticDumpsters.com also has local permit applications available for download.
Good Luck.
markgreen222 is offline   Reply With Quote
Old 01-01-2009, 10:03 PM   #12
Rewards Points: 162
You would be surprised how fast you can fill a 30 yard dumpster. I bought a 1800 sf cabin this summer and filled 1 1/2 30 yard dumpsters from the demolition of a small single car garage and general cleanup of the house. For me, the price difference between a 20 and 30 was $45. I was also allowed more tonnage in the base rate.
If you find you have extra room, offer up the extra space to the neighbors.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 05-13-2011, 04:32 AM   #13
hey i am very late to answer this question but idea is not old anyway.
yes should be try 30 dumpster i think.It is very good.
________________
Waste Companies
dumpster123 is offline   Reply With Quote
Old 05-13-2011, 08:49 AM   #14
A Little Of Everything
Rewards Points: 1,356
Holy buckets! Couple years ago (about the time this thread was started), when I was renovating a house I bought, we rented the biggest dumpster available for $180. The previous owner was a hoarder, so we filled it 3 times. I'm glad that "project" is in the past!
DrHicks is offline   Reply With Quote
Old 05-13-2011, 09:56 AM   #15
I work in the estate sale business. I did a hoarder project a few months back. He was a mechanic type - car engines, transmissions, plumbing parts, about 20 wooden doors (not for the house, just spare doors), wood, gross furniture, carpet, mowers, on and on and on.
3 dumpsters worth. Get good with an axe to make things smaller. That extra labor is worth saving on dump costs.
If there is metal, don't forget the metal yard. Made $1700 in metal alone - half from steel (heavy...) the rest from copper and brass (wire and pipes), lead, and stainless steel.
Found this, too:
aluminum13 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
What Size Dumpster ? Docfletcher Roofing/Siding 30 08-28-2007 02:06 PM
