-   -   Dumpster size for a house remodel? (http://www.diychatroom.com/f2/dumpster-size-house-remodel-10797/)
ashley 08-17-2007 10:33 AM
We are tearing out all carpet and linoleum, a tiled bathroom and shower, and just general trash and old paint, wood, etc left behind by the previous owners in a 2800 sq ft house. Do we need a 30 or a 20 size dumpster? Thank you!
shotdown 08-17-2007 08:53 PM
Not likely. I'm thinking more like 6' by 20'. Of course bigger is often (offen) easier but I've work BIG commercial construction jobs that don't use dumpsters THAT BIG!
ChrWright 08-19-2007 07:58 PM
I have to disagree.
Go for the 20... You will fill it easily. Be sure you roll the carpet as you take it out--it will take up less space.
slickshift 08-19-2007 09:34 PM
1) No way to tell from here
2) You'll find more stuff to throw in there if it's there
3) Your neighbors will find stuff to throw in there
4) Your relatives will find stuff to throw in there
Get the 30
robertcdf 08-19-2007 10:07 PM
I always get a 30... unless I know I only need 10 then I get a 20.
Cole 08-20-2007 05:10 PM
Get the 30
I couldn't agree more.
johnny331 08-20-2007 05:38 PM
The difference in cost between sizes is nothin' compared to the cost of getting a 2nd container!
I paid $30 to bump up from a 15yd to 20yd and should have gone even bigger.
Among other things, you wont have to be worried about packing everything so nice and tight in there...
jiggyjack 08-20-2007 07:07 PM
Check in your area but most Dumpster Companies will charge an arm and a leg if you throw paint in (It's considered Hazardous waste). Your best bet is to go to a local recycle place with the paint.
As far as size a 20Yrd should be more than big enough.
skymaster 08-20-2007 09:30 PM
only cost me 100 bucks to go from 10 to 20. Here not cheap tho, with a break 460 bucks for 20
Ron6519 08-20-2007 11:47 PM
Get the biggest one they have. Better to over estimate if this is a mysterious calculation.
Ron
markgreen222 12-31-2008 09:03 PM
Dumpster Rental answers
As far as sizes go, I would try going to www.domesticdumpsters.com. They have a FAQ section that helps to select the correct dumpster size. Also, don't forget about getting a permit for the dumpster. Most municipalities require the homeowner to obtain a permit before the roll off container is delivered. DomesticDumpsters.com also has local permit applications available for download.
Good Luck.
stubborn1 01-01-2009 10:03 PM
You would be surprised how fast you can fill a 30 yard dumpster. I bought a 1800 sf cabin this summer and filled 1 1/2 30 yard dumpsters from the demolition of a small single car garage and general cleanup of the house. For me, the price difference between a 20 and 30 was $45. I was also allowed more tonnage in the base rate.
If you find you have extra room, offer up the extra space to the neighbors.
dumpster123 05-13-2011 04:32 AM
hey i am very late to answer this question but idea is not old anyway.
yes should be try 30 dumpster i think.It is very good.
________________
Waste Companies
DrHicks 05-13-2011 08:49 AM
Holy buckets! Couple years ago (about the time this thread was started), when I was renovating a house I bought, we rented the biggest dumpster available for $180. The previous owner was a hoarder, so we filled it 3 times. I'm glad that "project" is in the past!
aluminum13 05-13-2011 09:56 AM
I work in the estate sale business. I did a hoarder project a few months back. He was a mechanic type - car engines, transmissions, plumbing parts, about 20 wooden doors (not for the house, just spare doors), wood, gross furniture, carpet, mowers, on and on and on.
3 dumpsters worth. Get good with an axe to make things smaller. That extra labor is worth saving on dump costs.
If there is metal, don't forget the metal yard. Made $1700 in metal alone - half from steel (heavy...) the rest from copper and brass (wire and pipes), lead, and stainless steel.
Found this, too:
http://i782.photobucket.com/albums/y...um13/moto1.jpg
http://i782.photobucket.com/albums/y...um13/moto2.jpg
http://i782.photobucket.com/albums/y...um13/moto3.jpg
