Dull Vinyl Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 12:22 AM   #1
Newbie Bill
Rewards Points: 520
dull vinyl floor
Hey Gang,
I scraped the popcorn texture from the ceiling in the kitchen this morning. Thanks to the information I got from this website.
However, I just let all that junk fall on the vinyl flooring and then swept it up and washed the floor a couple of times.
Now the floor is really dull. It almost seems like the dust and debris was abrasive. Was letting all that stuff fall on the floor a mistake?
I'm going to wash it a few more times to see if that helps.
Any other tips.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-14-2009, 07:29 AM   #2
Rewards Points: 5,336
I think this job called for a drop cloth, if for nothing else,ease of cleanup.
To test for abrasive damage, just clean a small area to see if this is indeed the issue. Don't use water at this point, clean it with a terry cloth and sweep or vacuum it up. Adding water will just turn it back to a slurry. After the dry wipe, see what it looks like. A clean sponge and a single wipe accross the surface will leave it as clean as it's going to get. Dry it and see what you have.
Ron
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Duraceramic tile over existing vinyl floor sjogren1 Flooring 1 03-15-2008 05:46 PM
Sheet vinyl over parquet floor? AllGoNoShow Flooring 6 10-26-2007 10:09 PM
Vinyl Floor troubles Keyo77 Flooring 10 10-15-2007 10:21 PM
Vinyl floor taylorguitar General DIY Discussions 1 02-21-2007 01:27 PM
