Drywall On Ceiling Of Bathroom - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 07:01 PM   #1
drywall on ceiling of bathroom
I have a downstairs bathroom with an enclosed shower that is just being finished. As I was getting ready to paint i noticed that the builder put in a normal drywall ceiling. i tried to contact the builder no luck. Can I leave the drywall and protect against mildew, mold and water damage? please help
dfarago is offline   Reply With Quote
Old 01-20-2012, 07:25 PM   #2
DIY staff
Rewards Points: 7,174
That's what is usually used for bath ceilings---not a worry---
Prime--and two coats of a high quality paint and you will be fine---
Old 01-20-2012, 07:27 PM   #3
Gymschu's Avatar
Rewards Points: 932
Dfarago, there was a time when "Green" board did not exist & walls in high moisture areas were painted & held up just fine. I'm sure installing green board in bathrooms is code so perhaps the contractor should come and make it right. I'll admit, I'm a painter of 35 years & I have painted over tons of regular drywall in bathrooms with no problems. If he won't replace it and you don't want to bother doing it yourself, I feel you can properly seal the drywall with a good drywall primer from Sherwin-Williams or Benjamin Moore and then topcoat with a quality 100% acrylic paint. Personally, I'm gonna say moisture resistant drywall is a bit overrated because anything that continually gets wet and stays wet eventually gets moldy or falls apart.
Old 01-20-2012, 07:37 PM   #4
Thanks guys! I was going to use a pva primer from home depot and the put two coats of Zinssers perm white, does that sound ok?
Old 01-20-2012, 08:35 PM   #5
DIY staff
Code does not require any thing different than regular drywall for ceilings---
I'll leave your paint brands for the pro painters---I am a Benjamin Moore guy---Never used the brand you mentioned,so I just don't know---Mike000
Old 01-20-2012, 09:07 PM   #6
Rewards Points: 150
We always use green (its purple now) board in all of our wets areas especially bathrooms because of the amount of moisture in the air when the fan isnt turned on. To meet minimum code is just getting by and thats not good enough for us.
If you want new drywall hung then have it done, and be prepared to pay for it if its not in your contract.
OhioHomeDoctor is offline   Reply With Quote
Old 01-21-2012, 08:05 AM   #7
Your Facilities Guy!
Absolutely just prime and paint, and make sure you have a good working exhaust fan in the room that will be just as effective as the missed green board option.
Donnig is offline   Reply With Quote
Old 01-21-2012, 08:25 AM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Make sure that you paint the ceiling with a anti-mildew paint or an anti-mildew agent added to the paint.
More Information here: http://paintpro.net/Articles/PP706/P...old-Mildew.cfm
- Build Well -
Old 01-21-2012, 09:16 PM   #9
thanks guys
Thanks for all your great tips
Old 01-21-2012, 09:37 PM   #10
Registered User
Rewards Points: 526
No greenboard, against code; "R702.3.8.1 Limitations. Water resistant gypsum backing board shall not be used where there will be direct exposure to water, or in areas subject to continuous high humidity." From: http://www.diychatroom.com/f18/bathr...lation-130901/
And it requires 12"o.c. at ceiling install with 1/2": "R702.3.8 Water-resistant gypsum backing board. Gypsum board used as the base or backer for adhesive application of ceramic tile or other required nonabsorbent finish material shall conform to ASTM C 1396, C 1178 or C1278. Use of water-resistant gypsum backing board shall be permitted on ceilings where framing spacing does not exceed 12 inches (305 mm) on center for 1/2-inch-thick (12.7 mm) or 16 inches (406 mm) for 5/8-inch-thick (16 mm) gypsum board. Water-resistant gypsum board shall not be installed over a Class I or II vapor retarder in a shower or tub compartment. Cut or exposed edges, including those at wall intersections, shall be sealed as recommended by the manufacturer." From: http://publicecodes.citation.com/ico...002_par013.htm
It does keep us busy replacing it after it turns to cottage cheese, though.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
federer (05-20-2014)
Old 01-22-2012, 04:21 AM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
forget that part' ,use a quality primer instead( 123)
Old 01-22-2012, 07:25 AM   #12
DIY staff
A bathroom ceiling is not a wet area---Properly primed and painted standard drywall is very acceptable.
The drywall mud is water soluble---If the bath ceilings were subject to the kind of moisture that would destroy the board---that tape and mud would have failed first--
It just doesn't happen--prime with a good primer--add two coats of a high quality paint and enjoy your new bathroom.
Old 05-20-2014, 04:03 PM   #13
Rewards Points: 968
so the finish of the paint is more important: using gloss vs flat latex
federer is offline   Reply With Quote
Old 05-21-2014, 07:21 AM   #14
Rewards Points: 5,978
Old post but the most important in my opinion is proper ventilation.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Maintenance 6 (05-22-2014)
Old 05-23-2014, 11:52 AM   #15
Rewards Points: 95
Drywall is transparent to water vapor, that is to say water vapor passes through it without problem. Drywall is always full of water and as such provides a 30 minute fire wall. If you don't want water vapor to pass through, paint with either gloss or laytex.
You do not want water vapor in your attic.......so paint.
Perry525 is offline   Reply With Quote
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Bathroom ceiling StevePax Drywall & Plaster 4 01-03-2010 12:32 PM
painting new drywall in bathroom LittleBrownDog Drywall & Plaster 8 08-18-2009 06:53 PM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 09:20 AM
excessive moisture on bathroom ceiling Den69RS96 General DIY Discussions 8 01-14-2008 08:37 AM
