-   -   drywall on ceiling of bathroom (http://www.diychatroom.com/f2/drywall-ceiling-bathroom-130774/)
dfarago 01-20-2012 07:01 PM
I have a downstairs bathroom with an enclosed shower that is just being finished. As I was getting ready to paint i noticed that the builder put in a normal drywall ceiling. i tried to contact the builder no luck. Can I leave the drywall and protect against mildew, mold and water damage? please help
oh'mike 01-20-2012 07:25 PM
That's what is usually used for bath ceilings---not a worry---
Prime--and two coats of a high quality paint and you will be fine---
Gymschu 01-20-2012 07:27 PM
Dfarago, there was a time when "Green" board did not exist & walls in high moisture areas were painted & held up just fine. I'm sure installing green board in bathrooms is code so perhaps the contractor should come and make it right. I'll admit, I'm a painter of 35 years & I have painted over tons of regular drywall in bathrooms with no problems. If he won't replace it and you don't want to bother doing it yourself, I feel you can properly seal the drywall with a good drywall primer from Sherwin-Williams or Benjamin Moore and then topcoat with a quality 100% acrylic paint. Personally, I'm gonna say moisture resistant drywall is a bit overrated because anything that continually gets wet and stays wet eventually gets moldy or falls apart.
dfarago 01-20-2012 07:37 PM
Thanks guys! I was going to use a pva primer from home depot and the put two coats of Zinssers perm white, does that sound ok?
oh'mike 01-20-2012 08:35 PM
Code does not require any thing different than regular drywall for ceilings---
I'll leave your paint brands for the pro painters---I am a Benjamin Moore guy---Never used the brand you mentioned,so I just don't know---Mike000
OhioHomeDoctor 01-20-2012 09:07 PM
We always use green (its purple now) board in all of our wets areas especially bathrooms because of the amount of moisture in the air when the fan isnt turned on. To meet minimum code is just getting by and thats not good enough for us.
If you want new drywall hung then have it done, and be prepared to pay for it if its not in your contract.
Donnig 01-21-2012 08:05 AM
Absolutely just prime and paint, and make sure you have a good working exhaust fan in the room that will be just as effective as the missed green board option.
AtlanticWBConst. 01-21-2012 08:25 AM
Make sure that you paint the ceiling with a anti-mildew paint or an anti-mildew agent added to the paint.
More Information here: http://paintpro.net/Articles/PP706/P...old-Mildew.cfm
dfarago 01-21-2012 09:16 PM
thanks guys
Thanks for all your great tips
Gary in WA 01-21-2012 09:37 PM
No greenboard, against code; "R702.3.8.1 Limitations. Water resistant gypsum backing board shall not be used where there will be direct exposure to water, or in areas subject to continuous high humidity." From: http://www.diychatroom.com/f18/bathr...lation-130901/
And it requires 12"o.c. at ceiling install with 1/2": "R702.3.8 Water-resistant gypsum backing board. Gypsum board used as the base or backer for adhesive application of ceramic tile or other required nonabsorbent finish material shall conform to ASTM C 1396, C 1178 or C1278. Use of water-resistant gypsum backing board shall be permitted on ceilings where framing spacing does not exceed 12 inches (305 mm) on center for 1/2-inch-thick (12.7 mm) or 16 inches (406 mm) for 5/8-inch-thick (16 mm) gypsum board. Water-resistant gypsum board shall not be installed over a Class I or II vapor retarder in a shower or tub compartment. Cut or exposed edges, including those at wall intersections, shall be sealed as recommended by the manufacturer." From: http://publicecodes.citation.com/ico...002_par013.htm
It does keep us busy replacing it after it turns to cottage cheese, though.
Gary
chrisn 01-22-2012 04:21 AM
forget that part' ,use a quality primer instead( 123)
oh'mike 01-22-2012 07:25 AM
A bathroom ceiling is not a wet area---Properly primed and painted standard drywall is very acceptable.
The drywall mud is water soluble---If the bath ceilings were subject to the kind of moisture that would destroy the board---that tape and mud would have failed first--
It just doesn't happen--prime with a good primer--add two coats of a high quality paint and enjoy your new bathroom.
federer 05-20-2014 04:03 PM
so the finish of the paint is more important: using gloss vs flat latex
ToolSeeker 05-21-2014 07:21 AM
Old post but the most important in my opinion is proper ventilation.
Perry525 05-23-2014 11:52 AM
Drywall is transparent to water vapor, that is to say water vapor passes through it without problem. Drywall is always full of water and as such provides a 30 minute fire wall. If you don't want water vapor to pass through, paint with either gloss or laytex.
You do not want water vapor in your attic.......so paint.
