Drywall Anchor Mishap - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 01:22 AM   #1
Rewards Points: 12
Drywall anchor mishap
Hi All,
Well... It started like this... Needed to install a gate at the top of a staircase. Since gate was installed at top of staircase, expected to find solid wood behind the drywall. This was the case on the one side, but not on the other (actually the real reason was that the woodscrews were not long enough to pass into wood once it made its way through the latch and guard assembly). So we proceeded to widen the hole and install plastic anchors. Anchors fitted snuggly, but the drywall crumbled as soon as I applied heavy torque (i.e. they start spinning in the hole). Then onto toggle bolts... (This was dumb, but it was 1am in the morning) Drilled 3/8 holes for toggle bolts, only to finally find wood (i.e. toggle bolts wont work since no gap at back) So now I have these huge holes... and I'm losing faith in my own ideas... Is there a drywall putty that will set strong enough to drill into (this time with longer woodscrews)? How about glueing wooden dowels into the holes, and then screwing woodscrews into these? Any other ideas?
JollyRoger is offline   Reply With Quote
Old 12-09-2010, 06:15 AM   #2
I would expect normal drywall compound or spakling to work. I doesn't need to be stronger than usual, since the screw will be going into the wood structure.
If you gate bracket is large enough to cover the existing hole, I see no reason even to fill it.
oberkc is offline   Reply With Quote
Old 12-09-2010, 08:01 AM   #3
Rewards Points: 5,336
Spackle the holes and use screws to get to the framing.
Ron
Old 12-09-2010, 08:38 AM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
It sounds like you are saying that when you tried to use the toggle bolts you ended up drilling 3/8" holes deep into the 2x4. Is this correct?
If so try to find a #A10 Alligator plug. I know Lowes carries the Toggler brand and some sizes of these, so I assume they stock the A10 ( which is the size that fits ina 3/8 hole). Stick these plugs in your holes, then use a number #10 - #14 sheet metal screw to attach your gate
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 12-09-2010, 08:47 AM   #5
howzabout a decorative piece of 1x2 or3 painted for gate to mount to. have used this with glue when no stud and has a nice finished look
The older I get the better I was
Old 12-09-2010, 04:11 PM   #6
Originally Posted by JollyRoger View Post
Hi All,
The fastest way to fill the holes is with plaster of paris which is very hard and cures very fast - in minutes. After filling the hole scrape off excess before it dries or you won't be able to smooth it out. I usually then cover with a fine coat of regular spackle which can be sanded smooth. You will then be able to drill for your screws
dadflynn is offline   Reply With Quote
Tags
anchor , drywall
drywall over old plaster... lcann25 Remodeling 0 09-20-2010 11:53 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
