Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-10-2007, 07:05 PM   #1
Drywall
The ceiling in my garage is of course, drywall. I want to attach a hanging device from my ceiling to carry a load of about 50-100 lbs. Do you have any ideas? Is drywall strong enough to handle that kind of a lad?
davidsj@sbcglobal.net is offline   Reply With Quote
Old 11-10-2007, 07:34 PM   #2
Eibwen
I dont think drywall will hold anywhere near that all by itself.
I would attach a board across a couple of ceiling joits with some lag bolts or if you have access above the garage run a board across the top of the ceiling joists and drop a hanger thru the drywall.
Sammy is offline   Reply With Quote
Old 11-10-2007, 09:33 PM   #3
Yep, You have to screw into the truss or block from the top. Cut a 2x8 to fit in between the trusses or joists...whichever you have.
localtradesman is offline   Reply With Quote
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
