Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-19-2007, 02:08 PM   #1
drywall
can i put drywall on the same wall as a fireplace.Will the drywall burn ,or do i need different material
ATEAM is offline   Reply With Quote
Old 10-19-2007, 02:41 PM   #2
you'll be ok........ the paper can Burn.... but it also allows for a Fire rating when used nt he correct thickness.
mdlbldrmatt135 is offline   Reply With Quote
Old 10-19-2007, 02:43 PM   #3
Your town can tell you what the code rules are for how far from the fireplace you must have a non combustible material, and details of overhangs near the fireplace. Other than that you can use drywall on a wall around a fireplace.
NateHanson is offline   Reply With Quote
Old 10-19-2007, 03:22 PM   #4
Lightbulb
drywall
what type of material do we use on a wall when thiers a fireplace in the center
Old 10-19-2007, 06:21 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes.
Refer to some examples of fireplace/firebox code requirements:
(Check with your local requirements)
http://www.fireplacesnow.com/mantel.html
http://www.rumford.com/certification/codes.html
- Build Well -
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
