Dryer Vent Exterior Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 01:01 PM   #1
Would like your opinions on this...
I have a dryer in the basement, which currently is running the vent on the outside (inside of house) of the 2x4 exterior wall.
I would like to finish this room off, and thought I may be able to run the vent in the wall instead. My only concern is the moisture build up/freezing in the winter as I live in Alberta, Canada and the temps can get quite cold as well as cleaning the vent itself.
Would I be ok to do this? Or should it be left as is on the outside of the wall?
Thanks!
MLayden is offline   Reply With Quote
Old 04-09-2013, 01:53 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
Running on the inside wall should be fine.
Depending on the length of the run, I might leave and access panel for a clean out location.
As long as it is inside the conditioned space and insulated, you should be fine.
The Following User Says Thank You to Windows on Wash For This Useful Post:
MLayden (04-09-2013)
Old 04-09-2013, 11:44 PM   #3
Registered User
Rewards Points: 5,204
No, only go directly through the wall for the termination hood, never across/up inside a wall cavity. The condensation would be constant, IMHO. This is why dryers are allowed 8' of transition ducting inside the room-from the dryer; http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
MLayden (04-10-2013)
Old 04-09-2013, 11:53 PM   #4
Gary
Perhaps I am misunderstanding what the OP was suggesting in this case.
I was thinking he was going to bulk out the wall to put it inside a finished space, not adjacent to an outside wall.
The vent does need to stay inside the conditioned space.
It may be okay inside a short run before going through the wall but unless it is run for a good bit before and after drying the close (i.e. to warm the space), it will form condensation on the quick.
Sorry for the confusion on my part and Gary is the authority on this stuff.
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 11:39 PM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 02:50 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
