Dryer Vent Condensation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 08:50 PM   #1
Woody10's Avatar
Rewards Points: 29
My dryer vent is about 8 ft long and is piped out a window. I just replaced the plastic type of duct with a flexible alum. duct. I just noticed that the top of the duct where the pipe comes in is very cold and there is quite a bit of condensation on it.
I have some insulation made for duct work left over from venting my bathroom exhaust fan. Would it hurt to wrap this around the pipe? I am wondering because it probably would get qute hot when the dryer is running.
Woody10 is offline   Reply With Quote
Old 01-13-2009, 11:17 PM   #2
Rewards Points: 2,906
If your existing duct is aluminum, then it'll take the heat.
You might consider replacing that duct in future with a 4 or even 6 inch "B" vent. These are insulated vents pipes, and they'd probably work a lot better than just wrapping insulation around your flexible aluminum duct.
Besides, typically on a dryer the regular and permanent press thermostat is 165 deg. F, while the delicates thermostat is 140 deg. F. 165 deg. F air is hot to the touch, but it's never gonna start a fire. You need both the thermostat and the high limit to fail before there'd be any concern about anything becoming too hot.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-27-2009, 03:14 PM   #3
Woody10's Avatar
Rewards Points: 29
Kind of bumping an old thread.
Is it safe then to spray foam insulation around the gaps of the pipe? Where the pipe and meets the duct and where the pipe and duct go out the window to the backyard?
I notice I have condesantion between the two windows and am trying to stop it.
Old 01-28-2009, 07:26 AM   #4
Rewards Points: 5,336
I would tape any open seams with metal tape. You can foam the areas that go outside or use a foamboard to surround the duct for a cleaner install.
Ron
Condensation accumulating in dryer vent. luckie_reubs HVAC 28 12-28-2016 11:29 AM
Help/moving dryer vent mjkpainting Plumbing 3 11-13-2008 08:44 AM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 10:03 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
