Dryer Vent - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-22-2013, 05:51 PM   #1
Rewards Points: 27
Dryer Vent
Hi everyone,
My roofer just installed this dryer vent. I'm wondering if someone can tell me from looking at this photo if the silicone around the vent is the proper material. It's the first time I've seen it this colour. It doesn't even look very well done. Can anyone comment?
Thanks.
triplex is offline   Reply With Quote
Old 12-22-2013, 06:19 PM   #2
Rewards Points: 13,300
That is one strange way to vent it.
What is that big vent really for?
Old 12-22-2013, 07:15 PM   #3
Rewards Points: 27
It's a gooseneck and it's on a flat roof. The other side of it is used for my A/C tubing for a mini-split air conditioner.
Old 12-22-2013, 09:06 PM   #4
Rewards Points: 626
well I am not a fan of silicone. I Would have used a product called quad caulk great stuff for out side use won't break down under UV and last for ever.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
triplex (12-22-2013)
Old 12-23-2013, 12:37 AM   #5
Registered User
Rewards Points: 5,256
As the dryer blows lint out will the AC pull it in there? Be certain the installer insulate/vapor barriers the ducting right out to the termination hood fitting or the moisture will condense in the ductwork to plug it and grow mold.
"M1502.3 Duct termination. Exhaust ducts shall terminate on the outside of the building. Exhaust duct terminations shall be in accordance with the dryer manufacturer's installation instructions. If the manufacturer's instructions do not specify a termination location, the exhaust duct shall terminate not less than 3 feet (914 mm) in any direction from openings into buildings. Exhaust duct terminations shall be equipped with a backdraft damper. Screens shall not be installed at the duct termination." From;http://publicecodes.cyberregs.com/ic..._15_par004.htm
Does this apply? "1. Closer than 10 feet (3048 mm) to an appliance vent outlet, a vent opening from a plumbing drainage system or the discharge outlet of an exhaust fan, unless the outlet is 3 feet (914 mm) above the outside air inlet." From; http://publicecodes.cyberregs.com/ic..._16_sec002.htm
Gary
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 08:55 PM
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 01:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 07:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 11:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
