dryer Outlet change 3 prong to 4 prong
If you look on the back of the dryer, the cord should be secured with several screws. It might be covered with a metal plate, so if it is remove the plate.
Disconnect the old cord and connect the new cord in its place. There should be a screw or bolt below the three wires that you can attach the green ground wire to.
You will not shock yourself as long as you unplug the dryer and do not reconnect it until the wire is secured.
Reason: Site Rules Violation: Advertising Link Removed From Signature
