Dryer Making A Whining Noise - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 10:33 AM   #1
Dryer making a whining noise
I'm new here, but have a problem I need some help with. I have an LG electric dryer (4.5 yrs old) that just started making a high pitched whining noise. I unplugged the dryer and lightened the load and that didn't seem to make a difference. Because of where our dryer is located it's hard to get at the back, and I'm 6 months pregnant. Thanks!
wendyknight is offline   Reply With Quote
Old 01-04-2010, 03:33 PM   #2
Rewards Points: 5,336
So from the description, I'm guessing the rear dryer vent has never been cleaned? Possible rear vent is partially blocked. That aside, you might have a bearing going bad.
Ron
Old 01-04-2010, 07:57 PM   #3
Household Handyman
Rewards Points: 1,408
First--with you being six months pregnant: DO NOT attempt to move or repair this dryer. Most electric dryers ( I have no experience with gas dryers) have two (2) "bearing blocks" located at approximately the 4 O'clock and 8 O'clock positions on the front of the dryer drum. When these start wearing down some (depending on dryer usage/cycles) these will cause some weird sounds with "whining" being one of the common complaints. These are replaceable, but the cabinet must be taken apart. And YES, there is a "bearing" so to speak in the back of the drum. These are not roller bearing, most are a bushing type bearing and they also will wear out, especially if the front wear blocks are worn. IF the front wear blocks are worn, the drum will drop down in the front causing the back bearing to prematurely wear out. Changing out the front wear blocks is not rocket science, but as I stated the cabinet will have to come apart, and dryer cabinets are built different by the different manufacturers. I would suggest to you that you visit www.repairclinc.com to see how your particular dryer is made. You will need the manufacturer, the model number, and probably the serial number (sometimes they change things during model runs). Others may chime in here with other suggestions and maybe other websites to help you. Good Luck, and take care of yourself for the next few months, David
Old 01-05-2010, 12:46 AM   #4
Registered User
Rewards Points: 5,516
While it is on, check at the duct termination hood outside, if accessible, for a good air exhaust. If not great, stop the dryer, let it cool and reach around in the hood area for lint build-up to remove the lint. If the clothes have been taking a longer than normal time to dry or not drying completely, the duct may be partially clogged: http://www.ashireporter.org/articles...es.aspx?id=161
If it needs servicing, have a type “A” hood installed for 50% more air flow: http://www.appliance411.com/faq/dryer-vent-length.shtml
Notice the loss for metal flex pipe.
Be safe, Gary
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 10 11-15-2016 09:53 AM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 11:25 AM
GE Dryer making loud scraping noise mcates Appliances 4 03-05-2008 02:05 PM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 02:45 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
