Drop Ceiling And Wood Burners - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 02:06 PM   #1
drop ceiling and wood burners
is drop ceiling safe above a wood burning stove
anthony thomas is offline   Reply With Quote
Old 02-19-2012, 02:11 PM   #2
Rewards Points: 13,446
How close is the stove pipe to the ceiling? Is it going through it?
Just a normal wood stove sitting on the floor will be no where the ceiling so why would you think there would be a danger?
Old 02-19-2012, 02:15 PM   #3
The track runs around the heat box above the pipe, so is kind of close . Also worried about the heat that will rise from the stove. thanks
Old 02-19-2012, 02:48 PM   #4
Any chance of a picture.
Rising heat off the stove it's self will not be a problum. If it was then houses with sheetrock ceiling would be busting into flames.
http://hearth.com/econtent/index.php...ling_it_safely
Old 02-19-2012, 04:06 PM   #5
Too Short? Cut it Again!
I take it the stove vents out the wall and not through the ceiling to the roof?
What material is the drop ceiling? Most drop in suspended ceiling panels are fire rated and if it is drywall, it probably is fire code material as well. Chimney/vent for the stove shouldn't hurt it.
Foam insulation might be problematical and could, I suppose, combust if too near.
Old 02-25-2012, 05:31 AM   #6
Usually, for your fire protective suspended ceilings is not necessary , because prevention is always better than cure.
annie wilson is offline   Reply With Quote
Drop ceiling with Steel Floor Joists stanlemon Remodeling 5 11-16-2010 04:11 PM
An extensive 'drop ceiling' project- where to begin... kpatten Remodeling 7 02-05-2010 06:31 PM
Custom homemade drop ceiling slowboyy Building & Construction 11 06-03-2009 06:16 PM
Removal of paneling and drop ceiling margog85 Remodeling 14 07-25-2008 03:13 PM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 05:30 PM
