Driveway Heaving Above Garage Floor (pictures) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 02:10 PM   #1
Driveway heaving above garage floor (pictures)
Hey guys, my house is around 6 months old and we have notices that our driveway is heaving about 1" above our garage floor (concrete breaking underneath brick work). The brick work is also pushing up against siding causing this to buckle. I have went around to a couple of the neihbors houses and thier driveways are not like this. Will the slab return to normal? Is this a warranty issue with the contractor? Thanks for any info.
Driveway heaving above garage floor (pictures)-image006.jpg   Driveway heaving above garage floor (pictures)-image004.jpg   Driveway heaving above garage floor (pictures)-image002.jpg
danreg99 is offline   Reply With Quote
Old 03-14-2011, 02:18 PM   #2
Experienced
Jackofall1's Avatar
Call the contractor, that is not what I would call acceptable. It is normal for a driveway to lift in the winter, but the way you are constructed has some concerns that need to be addressed.
Mark
Old 03-14-2011, 03:04 PM   #3
Concrete & Masonry
Rewards Points: 470
I agree, you've got good reason to be concerned.
This is exactly why an isolation material needs to be used between frost & non-frost protected slabs/structures.
jomama45 is online now   Reply With Quote
Old 03-15-2011, 08:20 AM   #4
Basically, you have moisture under you concrete that is freezing. Frozen water expands and hydraulically lifts the cement. Proper drainage helps. Looks like contractor needs to be talked too.
screwy is offline   Reply With Quote
Lip between Garage and Driveway formed over Winter ivanl3 General DIY Discussions 4 02-27-2011 03:35 PM
3" gap between concrete driveway and garage floor need to fill frankrizzo Building & Construction 0 11-23-2010 09:08 AM
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 09:07 AM
Water running from Driveway into Garage. CAD Building & Construction 5 06-17-2010 08:30 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
