Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-24-2009, 05:42 PM   #1
Driveway Drainage
I am needing to install some drainage at the bottom of my driveway,it unfortunately runs back towrds the house.Iam looking at putting a horizontal drain in the V where the two pieces of concrete meet at the expansion joint.I'm just not sure what to do on the outlet side.Should I bury perforated pipe with a sock over it or some type of catch basin?
CAnFlorida is offline   Reply With Quote
Old 02-24-2009, 07:27 PM   #2
Master General ReEngineer
Bondo's Avatar
Driveway Drainage
What's the lay of the land where it's draining too,..??
Can it just be daylighted,+ pitched away,..??
Old 02-27-2009, 12:49 AM   #3
Driveway Drainage
I deal alot with drainage problems, and I suggest a trench drain. You would need to cut a slot/channel in the concrete, dig out the substrate and reverse slope it outwards from your home structure, pour a concrete bottom in it and placee th trench grate over the slot. It's more a commercial/industril application, but i'm seeing it requested and used more and more on residential property, especially as an expansion joint/drain.
allencd@cox.net is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Question about convrete driveway Laser4G63 General Discussion 8 02-12-2009 06:19 PM
Muddy gravel driveway Ack Landscaping & Lawn Care 3 02-10-2009 03:38 PM
Heavy-duty roots in ground drainage pipe proofer Plumbing 11 08-06-2008 05:42 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 12:02 PM
