Drip Edge Overhang Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 08:24 AM   #1
Drip edge overhang issue
Roofers installed shingles with no overhang over the drip edge. Water runs down the shingles, over the drip edge onto the shadown board 1x2 in front of the fascia and onto the fascia.
How can this be corrected?
1. Remove the first course and reinstall the shingles to be 1/4 to 1/2 inch past the drip edge.
2. Insert a 4-5 inch section of shingle under the existing shingle to extend out past the drip edge end by 1/4 to 1/2.
Any suggestions would be appreciated.
trouts2 is offline   Reply With Quote
Old 08-30-2011, 08:35 AM   #2
Rewards Points: 150
call them back and make them fix it
organick is offline   Reply With Quote
Old 08-30-2011, 08:47 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Standard drip edges will do exactly what you described due to capillary action.
Manufactures have come out with a new drip edge called Rite Flow which holds the drip edge 1/2 - 3/4" off the fascia.
If you read down through this, you'll see they claim you don't need to rip off the existing drip edge.
http://www.lambritchie.com/catalog09.shtml
tcleve4911 is offline   Reply With Quote
Old 08-30-2011, 09:40 AM   #4
Organick,
Right but the issue is how.
tcleve4911,
Looks like it would work. It would be about the same as mounting drip edge away from the roof edge by to 3/8 ths. For very low angle or flat roofs some specs mention mounting drip edge away from the edge.
The roofers are currently starting two dormers and for those Im having them mount the drip edge away from the rake and edge and have at least shingle overhand over the drip edge.
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Newly Installed Roof Drip Edge question w/pics searayrunner Roofing/Siding 30 06-17-2010 12:14 AM
"F" type Drip edge & felt overhang caybound Roofing/Siding 5 11-07-2009 07:44 AM
Drip edge metal TVC15 Roofing/Siding 3 10-19-2009 02:06 PM
Shingle Overhang on Drip Cap? Dave M. Roofing/Siding 5 07-06-2008 04:46 PM
