Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-03-2011, 12:57 PM   #1
Drilling through floor joist
I have a floor joist I want to drill through for some electrical wire. There is already an existing hole drilled for some current wiring that came with the house. The floor joist is a particle board type nailed together. I attached a photo of the joist.
marly
marly is offline   Reply With Quote
Old 06-03-2011, 01:39 PM   #2
joed's Avatar
There should be holes in the joist ready to be knocked out with a hammer.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 06-03-2011, 01:41 PM   #3
Originally Posted by joed View Post
There should be holes inteh joist ready to be knocked out with a hammer.
I'm not talking about the I-beam floor joists with the knockouts. I'm talking about the one that is nailed together in the picture. It's made out of what looks like partical board.
marly
Old 06-03-2011, 02:22 PM   #4
I guess the correct name for the floor joist is, "Laminated Strand Lumber". There are two of them nailed together.
marly
Old 06-03-2011, 03:14 PM   #5
Moderator
Measure the two LVL's, if 1-32/4" each, that is what they are, pp. 23: http://imgs.ebuild.com/xCat/ebuildWe...riant=Original
If they measure 1-1/8" or 1-1/4", they may just be rim boards; http://www.ilevel.com/literature/TJ-4000.pdf (I hope not....)
Gary
Clothes taking longer to dry?
Old 06-03-2011, 03:28 PM   #6
Gary
They measure 1-3/4" (assume you meant 1-3/4 instead of 1-32/4"). They'are also used exactly how they're used in the picture on pp. 23 in the link you gave. They're buit around the stairs going into the basement.
I also have another joist similar that measure 3-1/2" that's labeled iLevel Truss Joist.
marly
Old 06-03-2011, 03:37 PM   #7
Moderator
Correct, I usually spell check myself, but have been sick at home today. That is my excuse and I'm sticking by it.... LOL.
Follow the guide or find the U.S. version on-line.....
Gary
Old 06-03-2011, 03:44 PM   #8
Gary
I attached another picture. I found on the back side it says, "Trus Joist" and it also says "hole zone". I assume that's where it's ok to drill.
Old 06-03-2011, 04:43 PM   #9
Moderator
Just follow the picture guides as they appear the same: http://www.ilevel.com/literature/TB-209.pdf
http://cmfac.groups.et.byu.net/tharm...ng%20guide.pdf
http://www.google.com/search?client=...=Google+Search
Gary
Drilling holes in concrete slab spaceman spif Building & Construction 12 10-18-2010 10:10 PM
Drilling asbestos siding (hanging shutters) MichaelDutch Remodeling 3 06-15-2010 11:49 AM
Help: Drilling into concrete or stud? rev1976 Building & Construction 7 05-11-2010 02:47 PM
Granite countertop drilling options dantm General Discussion 1 02-09-2010 01:42 PM
Drilling Holes Through Foundation quickquestion Building & Construction 3 01-10-2010 01:42 AM
