Drilling Holes For Exterior Security Camera Ac Plug - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 06:57 PM   #1
Rewards Points: 119
drilling holes for exterior Security Camera ac plug
I obviously don't want to plug it into an exterior outlet. I need to drill a hole through until the interior. What do I put inside the hole, I don't think I want to just drill a hole and feed the plug wire through it do I?
drilling holes for exterior Security Camera ac plug-b003x26lyq_awning_setup_lg.jpg
SpaceCoast is offline   Reply With Quote
Old 02-03-2014, 07:24 PM   #2
Rewards Points: 6,652
Three words. Power Over Ethernet, if this is a IP camera setup.
Old 02-03-2014, 08:45 PM   #3
Rewards Points: 119
Yes, I need a setup to watch home exterior over internet/iphone. Recommendations for cameras?
Old 02-03-2014, 09:02 PM   #4
I use a Foscam FI8905w on my garage. Never have had any issues with it. They make a POE version. For the switch, get something like the TP-Link TF-SF108P. It has four 15.4w POE ports. http://www.newegg.com/Product/Produc...82E16833704080
Also make sure you get an Ethernet Lightening Protector, like this. http://www.l-com.com/surge-protector...era-protectors. L-Com also sells POE injectors, that have Lightening protection. http://www.l-com.com/surge-protector...-poe-injectors
Old 02-04-2014, 01:01 PM   #5
Rewards Points: 119
So just going with ethernet cable connection or wireless with wifi is not good?
Old 02-04-2014, 01:04 PM   #6
You need to go with what I stated. Unless you place a large enough sized box on the side of the house, with a outlet box inside it, you need to just go with POE (Power Over Ethernet), or with a Coax connected camera, that uses a balun to allow power to be connected to the camera.
Just follow the info I gave you, and it will work. Trust me on this. I do this stuff for a living, and have been around this stuff for over 26+ years.
Old 02-05-2014, 12:34 AM   #7
Rewards Points: 119
Will do thanks.
Drilling straight holes without drill press pomelo Carpentry 17 01-24-2012 06:47 AM
Drilling Shelf Pin Holes in Existing Shelf Red Truck Carpentry 7 05-11-2010 09:27 AM
Help with drilling large holes in marble tile crashley1784 Tiling, ceramics, marble 4 03-02-2010 02:25 AM
plug basement weep holes for the winter?? captjackny HVAC 1 01-27-2009 06:23 PM
Plug up holes in wood fw2007 Carpentry 5 09-10-2008 01:38 PM
