Drilling In Concrete Block? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-03-2010, 05:12 AM   #1
Drilling in concrete block?
I need to drill ten 2" holes about 10" into concrete block (down into the top of a filled block wall). I do have a rotary hammer drill; is it feasable to use that with a masonry bit that large or do I need to rent a core drill rig?
Curious... what are the differances between a hand held core drill motor and a regular large drill motor? Can you use a regular drill with smaller coring bits?
Thanks...
Gary
Gary Sutherland is offline   Reply With Quote
Old 05-03-2010, 06:55 AM   #2
DIY staff
Rewards Points: 7,174
EBAY has cheap diamond core drilling bits.
A core drilling drill is like a drill press with with a rubber suction base and a water pump.
That wouldn't do what you need any way. A slow drill --plugged into a gcfi outlett ---and a hose set to a dribble is the way.
By the way--good quality core bits cost$$$ We figure about $100. per inch. 2" bit $200--6"--$600
Makes for an expensive hole--I've never tried the cheap Chinese bits--Might be fine for a few holes.
-----Mike------
Old 05-03-2010, 10:37 AM   #3
Household Handyman
Rewards Points: 1,408
From experience, having done this: They do make core drills which use suction type bases, these won't work for your project. They do make core drill with use "Hilti" type anchors to hold the base in place while drilling, this works better on rough surfaces. These are available for rent at most equipment rental places. You may have to prove/convince them that you have experience with these. You will also have to sign for the wear/tear on the bits, or even agree to pay for one if it breaks. EXPENSIVE! Drilling 10" deep into poured concrete (rebar?) can be done, but slowly. You will be using water as the machine requires it. IF the concrete is more than the 10" deep and you only want to go 10" deep, then drill to that depth, pull out, and smack the plug with a sledge hammer directly on top of the plug. This has worked for me to break the bottom of the plug loose. Use a "Hilti" type anchor drilled into the plug for removal. We set many safety guard rails into place in an 18" deep concrete floor this way. The 2" holes should be easy enough. David
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
stone foundation to block or concrete Suzuki91vx800 Building & Construction 6 06-21-2009 04:34 AM
Styrofoam Concrete Block Basements packfan-isugrad General DIY Discussions 2 06-16-2009 03:22 PM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 04:07 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
