Originally Posted by garyoutwest
I want to add a 16" "wrought iron" fence to the top of a low cinder block wall
One thing that no one has brought up yet is to ask how do you know that this is cinder block vs concrete block? There is a big difference in strength
http://www.us-concrete.com/products/masonry.asp
Another thing is how High is the block wall?
Another important thing that has already been asked is how wide is the Block? It is most likely 4, 6, or 8" block. This is an important question. . If its 4” block then it may be impractical.
When you say:
....The wall is filled and topped with red brick...
I infer that that the open cells in the block have been filled with grout. If that is correct, how do you know this because the wall is “
topped with red brick”?
If the brick topping was added after the block was laid the grout IMO only has a 50-50 chance of extending down to the base. A common technique was to wad up some newspaper and jam it down in the top row of block then just trowel it off or add a row of bricks or some type of precast wall cap or stone.
A big consideration is whether or not the wall was built with a descent footing and vertical and horizontal
Rebar
If the wall is 4’ H or less, I would guess that you have <50-50 chance on the foundation/rebar issue.
- More info
- Pics
- Driil a few ¼” test holes down about about halfway down the top row of block to check for grout filled cells. To make sure you are not just drilling into the block webbing, space some holes a couple of inches horizontaly.
You can buy a coring bit that has a centering drill
http://www.toolsforless.com/product/...entering_Drill
