Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-12-2008, 11:12 AM   #1
drilling in ceramic floor tile
I"ve been installing several door stops in a house that we're building - the floor is ceramic? tile- very hard! the drill bits that we're using are the spear point carbide - they work well for two- three holes- I've got a can of cold water to dip them into every 1/2 minute or so- but even still, they wear out, or usually the carbide tip falls off - so in looking for something else more suitable, I've found diamond drill bits (on the net) has anyone used these? are they an improvement? I'd hate to spend 20 bucks on a bit to have it wear out in a few holes.
thanks!
Mac!
mrmac204 is offline   Reply With Quote
Old 04-13-2008, 09:35 AM   #2
The heating and cooling cycles are killing the bits. Maintain cool water on them at all times, not every 1/2 minute or so.
However, a diamond bit is well worth the investment but you have to keep it cool too. I just use a small spray bottle of water and keep a flow on the work surface. This also helps flush away the material you have already cut. A couple of rags on hand will expediate cleanup.
Gencon is offline   Reply With Quote
Old 04-13-2008, 01:56 PM   #3
nap
You talking to me?
nap's Avatar
ditto
build a dam of rags around the area you are drilling.
Personally, I maintain a dribble of water on the bit at all times.
Old 04-14-2008, 10:16 PM   #4
remodeling pro
Two points come to mind for your difficulties. Ceramic tile is generally not that hard, could it be porcelain? Secondly, are you using a hammer drill or a rotary hammer. Hammer drillls, especially inexpensive ones, are really bad for melting drill bits in hard materials, as they have very little hammering action, even though they make a heck of a lot of noise, so the bit just spins and generates heat until it disintegrates. I would suggest switching to a Bosch or Hilti peercussion bit over the little spear point types.
troubleseeker is offline   Reply With Quote
Old 04-14-2008, 10:27 PM   #5
nap
You talking to me?
nap's Avatar
hammer drills break tile very easily. If one is not experienced drilling tile with one, I will guarantee at least one broken tile.
I would stick with the little arrow bits and water and a slow drill.
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 10:45 PM
Will Ceramic Tile Stick to This? average Remodeling 3 06-28-2007 01:20 PM
is this subfloor strong enough for ceramic tile ? mf915 Flooring 2 07-01-2006 08:02 AM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
