Drill Bit Sharpening - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-05-2013, 11:02 PM   #1
Lord of Slums
Rewards Points: 1,974
Drill bit sharpening
Okay, I have seen the complex expensive looking machines on youtube that are used to sharpen drill bit. I watched a few bench grinder videos where the drill bit is like new. I have seen the home owner machines that sharpen bit. Can someone get to the bottom of the question. Is it worth it to sharpen common sized drill bits? Have it done? Buy new? Buy a basic machine? By hand with a file.
mj12 is offline   Reply With Quote
Old 06-06-2013, 12:05 AM   #2
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
We have a Drill Doctor unit at work, it works, sort of, it doesn't give the greatest results. It cant sharpen bradpoints, multi spur bit, and does a lousy job on any bits smaller than about 1/4"
We just buy bits in bulk, most of the times smaller ones break before ever needing sharpening anyway.
Personally I wouldn't waste my money on a sharpener.
Sculpture scholarship recipient, 2008
Asbestos information: http://www.diychatroom.com/f98/asbes...pt-1-a-181840/
RWolff is offline   Reply With Quote
Old 06-06-2013, 06:01 AM   #3
Rewards Points: 13,446
I sharpen all mine with a grinding wheel on a pedistal grinder. Anything less then about 1/4 gets tossed. Just to tricky to sharpen a really small drill by hand.
Just takes a little practice.
Go easy and keep the bit cool.
Old 06-06-2013, 07:55 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,996
Seems like more and more stuff is throw away now.
Best thing to do is like Joe said, keep them as cool as you can.
I have a drill doctor but can't confess to having used it more than a couple of times.
Old 06-07-2013, 07:29 AM   #5
Rewards Points: 5,974
What I did was buy a cheap set then as I replaced broken ones I would replace with good bits. That way the ones you use the most are good ones and you have the others for that odd time you may need them.
Old 06-07-2013, 07:50 AM   #6
Rewards Points: 2,634
I agree that small bits will break before needing sharpening. I sharpen bits on my bench grinder. Its hit and miss for me --- sometimes I get it right and sometimes I don't. If the bit has difficulty cutting after "sharpening", I pull it out of the chuck, and try again. If I can't get it to cut well, I figure I overheated it and ruined the heat-treat. Its only noticeable when drilling steel --- I am not sure if I would even notice a dull bit when cutting wood.
SPS-1 is offline   Reply With Quote
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 07:00 PM
Sharpening Rotary Hammer Concrete Drill Bit daltinator Tools 9 02-03-2012 07:39 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 09:53 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
