Drainage Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-19-2009, 05:28 PM   #1
Smile
drainage problem
I am having a drainage problem
When i flush the toilet every thing is ok unless i take a shower or was some dishes or even shave when i do these the toilet will gergle and then i have to wait about 2 hrs before i can flush the toilet again.
Can some body tell me why it is doing this and how i can go about getting it fixed.
Thanks Ruben
ruben williams is offline   Reply With Quote
Old 02-19-2009, 05:54 PM   #2
Remodeling Contractor
The vents are clogged somewhere. The toilet has enough water to flow freely. The others are not flowing as fast. The vent should help equalize this pressure, but since it is not working water is siphoning from the toilet trap. Which tries to refill slowly and you hear it.
Old 02-20-2009, 10:58 AM   #3
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Snake the "stinkpipe" from the roof.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 02-20-2009, 11:36 AM   #4
I agree it is a venting problem. Look at your roof and you should see one (or more) pipes sticking through it. These are vent pipes. In the winter, spiderwebs can collect condensate and freeze, birds can build nests on/in them or an animal seeking warmth, can fall down them. If it is safe, go onto the roof with a flashlight and examine the pipe(s). If clogged, remove all you can by hand and then flush the line with a garden hose.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Sump pump drainage problem sk8z Plumbing 6 11-29-2008 10:09 PM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 07:38 PM
Drainage problem - Rain Barrel? Leah Frances Landscaping & Lawn Care 4 01-30-2008 06:20 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
deck drainage problem darsunt Building & Construction 4 12-30-2006 12:45 PM
