Drainage Diagrams - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 03:12 PM   #1
drainage diagrams
Hi i have a reaccuring problem with my drain and no matter how many times i contact the council they are saying that it is my problem to deal with, i believe that the blockage is coming from further down the street i want to start proving to the council how this cant be mine. does any body know where i can find the diagrams for my local area including depth and falls, any help would be appreciated.
twotechnical is offline   Reply With Quote
Old 02-01-2010, 04:59 PM   #2
Rewards Points: 582
The council are not responsible for drainage. In Essex it will be either Thames or Anglian Water.
What exactly is the problem you are having? Are you getting a blockage at the last manhole before the run enters the main sewer in the street?
stuart45 is offline   Reply With Quote
Old 02-01-2010, 09:37 PM   #3
i dont think im at the end i would say more at the start, the drain in question blocks up every 3-4 months and when i rod them myself i dont hit anything underground for 16 mtr, this passes 1 other house and is almost at the second house along, i dont know what is causing the blockage however im sure it isnt myself. i have contacted both the water company and the council and both say it is down to me as the manhole is on my property, they are also telling me that nobody else in my area is reporting this fault.
Old 02-02-2010, 05:14 AM   #4
Rewards Points: 582
Does the drain run go through the front gardens or along the street? If it's the old salt glazed pipes set in concrete, blockages are often caused by ground movement cracking the concrete and pipes and forming a lip inside the pipe where stuff builds up.
You may need a drainage survey to prove the fault is not yours.
Old 02-02-2010, 06:59 AM   #5
if i was standing with my back to my front door it runs directly away from me with my neighbours connecting form either side at approximatley a 45 degree angle,it is a salt glazed pipe. Would i have to hire a private contractor to do this or should i contact the water company and request them to do one? cheers
Old 02-02-2010, 12:14 PM   #6
Rewards Points: 582
It depends on whether the drain is a private or public sewer. Any drain serving more than one property built before 1937 is usually a public one and the reponsibility of the water company. They should have plans of the public sewers.
Old 02-02-2010, 02:08 PM   #7
ok mate i will start contacting the water company.
thanks for your help much appreciated
drainage issue jeremiah1 Building & Construction 4 12-14-2009 07:32 PM
Stubbies Diagrams and other stuff Stubbie Electrical 1 09-04-2009 10:54 PM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 12:05 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
