Drain Pipe Vermin - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-27-2012, 11:48 AM   #1
Drain pipe vermin
I have my gutters drain underground to daylight at the back of my yard. I kept noticing the cap pushed off. I secured it with tape. Found it chewed away. Any idea what might do it? Also. Are there any one-way caps that would allow water out but close when dry, like a dryer vent cap? Or should I drill holes in a metal cap and secure it with sealant (coffee can lid for example). My fear is whatever it is will find it's way up through the gutters and into the attic...
Drain pipe vermin-image-2841139007.jpg   Drain pipe vermin-image-4162398673.jpg   Drain pipe vermin-image-2618093838.jpg
Slyguysmoke is offline   Reply With Quote
Old 06-27-2012, 12:03 PM   #2
Rewards Points: 152
My guess would be chipmunks or squirrels, probably after maple helicopters, or the droppings of whatever other trees may be overhanging your eaves trough. Probably not a lot that you can do about it, since they have obviously figured out where their dinner comes from. It seems doubtful that they could climb the inside of the downspouts, even if they wanted to, but, nevertheless, that by itself should not provide them access to your attic.
Old 06-27-2012, 01:55 PM   #3
Rewards Points: 14,306
A cheap thing to try would be a piece of 1/4 grid galvinized screening and a hose clamp. One I like has a thumb screw on it. It's really made for dryer hoses but it's simple to get off and on with no tools. Lowes has them.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
PVC sink drain pipe... Ed911 Plumbing 4 12-01-2011 10:09 AM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 01:48 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
