Drain Cleaning Machine - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 10:17 AM   #1
DeeKayVB's Avatar
I saw this in the HD website n wondering if it's a good investment. I have an older house n been having plumbing issues lately. Someone on this site just told me to quit the liquid plumbers!
Please share thoughts and experiences.
DeeKayVB is offline   Reply With Quote
Old 02-23-2012, 10:19 AM   #2
Rewards Points: 13,300
Far better to get rid of the old cast iron pipes and make any needed corrections to plumbing then having to keep having to clean out the pipes.
PS you did not attach what it was you were thinking about buying.
Old 02-23-2012, 10:23 AM   #3
DeeKayVB's Avatar
It's the Rigid drain cleaner--I don't have a pic at the moment. I don't have enough plumbing skills to replace old pipes and wouldn't that involve tearing down walls?
Old 02-23-2012, 10:35 AM   #4
No clue, there are no pictures, no one knows if you have a crawl space of full basement, where the drain is that's cloging, first floor second floor?
Is this a slab house? Septic tank or city sewer.
Old 02-23-2012, 07:59 PM   #5
Rewards Points: 150
I use power washer with special hose and valve to clean drains.
CaptRandy is offline   Reply With Quote
Old 02-23-2012, 08:19 PM   #6
Call in a plumber to have a look if you do not know how to do it.
Old 02-23-2012, 08:23 PM   #7
jschaben
Rewards Points: 502
Hi Kay , Is this the one your looking at?
http://www.amazon.com/Ridgid-34963-A...=cm_cr_pr_pb_t
I picked up one of these and works pretty well on the small stuff. Over about 2" though it isn't big enough to do the job. Just what kind of issues have you been having?
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 02-24-2012, 05:39 PM   #8
DeeKayVB's Avatar
Yes, that's the one. I have a slow draining bathroom sink. Prior to that, I had a slow draining bathtub but that I fixed with liquid plumber. I was thinking about basic maintenance.
Old 02-24-2012, 09:07 PM   #9
Rewards Points: 940
As for the lav drain, you might want to just take off the trap and clean it out.
You look you have nice long hair. If you pull the strainer off the shower drain, you will find a big handful of it hanging in the drain. There might be an 8-12" wad of it hanging there. This can be cleaned every 3 months.
cleveman is offline   Reply With Quote
Old 02-24-2012, 09:36 PM   #10
jschaben
Rewards Points: 502
Hi Dee - I agree with cleveman, if the trap is accesible, it's just as easy and not much more mess by just removing the trap and cleaning it out. Also preferable to chemical treatment. About the only tools needed would be a couple of pair of waterpump pliers but most of the pvc fittings just need to be hand tightened anyway. The trap is the larger "U" shaped pipe under the sink, directly below the drain hole.
Did someone say POWER WASHER
John Schaben
Old 02-24-2012, 10:08 PM   #11
A Little Of Everything
Rewards Points: 1,364
I've got one similar to that, except that it's powered by a drill. I've opened several drains with it. For what it is, and is supposed to do, it works pretty well.
DrHicks is offline   Reply With Quote
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Leaky Washing Machine Drain Pipe sweetwaters Plumbing 17 02-14-2012 09:50 AM
Septic odor from washer machine drain TMC Plumbing 4 02-02-2012 08:40 PM
Washing Machine Drain Pipe overflows evol200 Plumbing 3 01-27-2011 01:41 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
