Drafty Windows - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 09:00 PM   #1
Drafty Windows
Had new vinyl replacement windows installed in our house about 6 years ago. Low E, double pane and the type that tilts for easy cleaning. Well every window in our house leaks at the point where the insulation or seal is between the stationary part of the window and the part that tilts. It is ironic that all of the windows leak at those points. My question is if I can put a thicker seal or insulation between the two points or just install window kits? Is this normal for tilt windows to leak over a period of time. Very curious now. Thank you for any advice...Ray
raiderray75 is offline   Reply With Quote
Old 01-14-2010, 05:50 AM   #2
They should not do that. Most windows have a 10 yr warranty for mechanical components, contact the manufacturer and the installer/seller. If a manufacturing defect they will fix it. If an installation defect, that is up to the installer, but the manufacturer can advise or help.
Old 01-14-2010, 07:14 AM   #3
Remodeling Contractor
Do you have the locks in the locked position. Windows will only show leaks here if left unlocked or faulty.
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 09:57 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Replacing old drafty windows MH1980 Remodeling 3 07-04-2007 04:23 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
