Drafty Electrical Outlets And Switches - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-28-2014, 04:25 PM   #1
Drafty electrical outlets and switches
Is spray foam a good solution for this problem? I can see the vapor barrier has been cut behind the boxes
jimmyburgers is offline   Reply With Quote
Old 03-28-2014, 04:36 PM   #2
FIDO...
Rewards Points: 237
Have you considered first trying something along these lines?
http://www.homedepot.com/p/Frost-Kin...S12H/100184290
Cheers, Chris
Chris130 is online now   Reply With Quote
Old 03-28-2014, 05:48 PM   #3
Oso954's Avatar
Rewards Points: 420
Spray foam (such as great stuff in a can) is flammable. I would not use it anywhere that it might close an opening in the box or enter the box.
Oso954 is offline   Reply With Quote
Old 03-28-2014, 07:24 PM   #4
Rewards Points: 12,808
Sounds like someone has not air sealed the places in the crawl space, basement, attic where the wires where run though the plates.
Not sure where Oso's getting that info but walls acting chimneys is a far bigger danger.
No air flow no fire.
Old 03-28-2014, 07:59 PM   #5
Rewards Points: 6,652
Foam around the boxes with DAP foam in the can, along with a small squirt where the wires enter the box. Just do not fill the box all of the way with foam, like some people do.
Also make sure you foam around the Windows & doors, behind the molding around them.
Old 03-28-2014, 08:40 PM   #6
Baby safety plugs ..works great..
creeper is offline   Reply With Quote
Old 03-28-2014, 09:17 PM   #7
Rewards Points: 100
To clarify, electrical boxes have openings. And wires run through some of same, but the others still have gaps around them to make it easy to punch them out. In the house I am currently working on, we hit the unused openings with silicone caulk, thine same around the wires for the used endings. Plastiic vapor barrier was then silicones to the sides of the box prior to sheetrock....and then the ending was sealed after plaster. This has NOTHING to do with places where wires run through plates, etc.....since time walls are cold on the outside......and the house is warm....and there will be some air transfer between the two temps regardless. That said, your house is of tight and you run into moisture problems and have to run an exhaust fan in the bath or whatever for various times during the day. Ron
ront02769 is online now   Reply With Quote
Old 03-28-2014, 09:40 PM   #8
The baby plugs cost a few dollars. Put your hand in front of the outlet and you will see that the draft has stopped
Old 03-28-2014, 10:45 PM   #9
iminaquagmire's Avatar
Rewards Points: 338
The baby plugs don't solve the real problem though, they just take away a symptom. As joecaption said, fill the holes where the wires go through the top and bottom plates and you won't have air movement through the wall to create the drafts. That's more inefficient than drafty receptacles. If you can get around the boxes with spray foam, then that's great but you should be looking elsewhere first.
iminaquagmire is offline   Reply With Quote
Old 03-29-2014, 12:37 AM   #10
Rewards Points: 744
Not even the fireblock foam, which comes in the orange can? http://www.homedepot.com/p/GREAT-STU...5372/202023037
Seattle2k is offline   Reply With Quote
Old 03-29-2014, 02:14 AM   #11
Oso954's Avatar
Rewards Points: 420
6. Cured foam is combustible and will burn if exposed
to temperatures above 240F (116C). Do not
apply GREAT STUFF™ foam around heaters, high heat lamps or recessed lighting fixtures, radiators,furnaces or fi replaces where it could contact heat-conducting surfaces. Do not use GREAT STUFF foam inside electrical boxes or panels (applications around the boxes are permitted)
http://greatstuff.dow.com/pdfs/consumer_safety.pdf
It is Item 6 on Page 2 of the Dow Chemical Consumer Safety Sheet.
I don't have a problem using it to seal a studbay, but the op was talking about using it directly behind the box to seal a vapor barrier. Depending on the spacing it could be a problem. If an arc or molten slag from an arc could possibly hit it, I don't want it there.
Old 03-29-2014, 02:41 AM   #12
Oso954's Avatar
Rewards Points: 420
If you want something that will not support combustion look for something that says "firestop" or "fire barrier". 3M firestop products would be an example.
If it says "fire block" the product will often support combustion.
Greg: I haven't found any specific statements from DAP, but I can tell you that in my on tests on it, once ignited, it supports combustion better than Great Stuff.
3 Electrical Outlets Stopped Working iherduliekme Electrical 14 02-11-2013 08:00 PM
electrical outlets & switches waterloo Electrical 1 04-07-2012 08:08 PM
Wiring multiple outlets, switches and lights Bubski27 General DIY Discussions 3 11-09-2011 07:54 AM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
Replaced outlets, now wall switches don't work? PittsburghPaul Electrical 3 08-09-2009 06:50 PM
