Down Spouts - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-15-2013, 05:54 PM   #1
Rewards Points: 154
Down spouts
Are there any down spout fittings that I can buy that will go around a corner? Here is a photo of what I'm looking for. I suspect that I will have to crimp my own fittings.
ovahimba is offline   Reply With Quote
Old 06-16-2013, 10:44 AM   #2
Pro
Rewards Points: 91
I've never seen anything pre-made like that. It's easy enough to put together out of stock pieces, though.
CarpenterSFO is offline   Reply With Quote
Old 06-16-2013, 08:38 PM   #3
Lord of Slums
Rewards Points: 1,974
are you looking for square downspout? It is not very difficult to make yourself. Surprisingly I have never seen pre made fittings like that.
mj12 is offline   Reply With Quote
Old 06-16-2013, 09:51 PM   #4
Rewards Points: 154
I'll probably experiment against a wooden box with a series of elbows like a flat 45, then regular 90, then another flat 45 down. Aluminum seems easy to manipulate. It just may not look as pretty as I would like.
Old 06-16-2013, 09:57 PM   #5
Rewards Points: 958
That is just stupid. Choose a side of the building to run down and stick with it.
cleveman is online now   Reply With Quote
Old 06-16-2013, 11:20 PM   #6
Rewards Points: 154
When remodeling and doing additions you often run into unique problems. Obviously if this were new construction I wouldn't do that. But since I added a high deck, one diagonal section under a cantilever is now at eye level and needs to be moved. I suppose I could reposition the drain by drilling a new hole in the gutter and pluging up the old to get around the corner.
Old 06-17-2013, 06:47 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
Your picture appears to be PVC. 2 45, one 90 and a couple of stubs. You can easily do it in aluminum as well. I have seen flexible stuff that can be bent any which way at Menards but it looks way too down home for me.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-17-2013, 07:14 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,676
Plenty of ways to effectively do this in aluminum. Look for a B elbow.
gutter spouts valpd Building & Construction 14 05-25-2013 11:12 PM
Removing Stubborn Tub Spout 347Cougar Plumbing 6 12-27-2012 03:12 PM
want to put heat tape but I have 3 - 22' down spouts Patt47 Roofing/Siding 3 12-05-2011 05:23 PM
Weeping/Drainage Tile for non-continuous walls billyh Building & Construction 2 03-31-2011 09:13 PM
a stupid question about tub spouts farmerde Plumbing 6 01-15-2009 06:20 PM
