Double To A Single Sink - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 09:47 PM   #1
Double to a single sink
Planning on removing our double sink and replacing it with a single sink. Currently one sink has a disposal on it and the other does not. Are there any issues or special considerations for changing this to a single sink?
Ehsoccer15 is offline   Reply With Quote
Old 02-25-2011, 09:52 PM   #2
Rewards Points: 558
Yeah unless you are changing your counter top and cutting out a new hole for your new sink.
epson is offline   Reply With Quote
Old 02-26-2011, 07:20 AM   #3
Rewards Points: 5,336
Get the same size sink and you won't have any problem.
Ron
Old 02-26-2011, 08:22 AM   #4
We found the same size sink in a single, obviously important. My concerns are plumbing. Right now each sink goes to it's own drain, plus the dishwasher drains into one. When I replace the sink do I put in a T to both drains or just cap one? I don't know the reasoning behind the separate drains. Also the new drain will be in the middle of the two so any preference on running the pipe over before going down and up or going down and up then running the pipe over?
Old 02-26-2011, 12:25 PM   #5
Never saw 2 individual drains. Usually 1 trap going up to a "T" where it branches to each sink drain. The dishwasher would be connected to the vertical drop pipe.
I'd use the drain closest to the dishwasher and cap the other. Pipe the sink in the usual manner to the wall outlet.
Ron
2 Single Poles to 1 Double GFCI Breaker nuckphoto Electrical 24 11-10-2010 11:40 PM
This won't work will it? (double sink) USP451 Plumbing 1 02-05-2010 02:36 PM
single to double gang remodel DIYGST Electrical 3 01-02-2010 06:33 PM
single pole vs. double pole circuits DannoW Electrical 7 07-21-2008 09:20 AM
single vs. double breaker Neil_K Electrical 3 11-14-2004 11:02 PM
