#1 |
double glass window pane problem-
People,
I have a window with double pane-abiout 12"x14" or so, outside pane plate glass broke, and removed it from the frame. Its on the bench. Is there a good way to remove the shards of pane glass stuck to the tacky adhesive (on the inside/middle of the 2 panes) as I doont even need the double pane thing. The shed isnt even heated/cooled. If I can remove rather cleanly, it will save me the hasle/expense of sourcing a new one.. Thanks |
#2 |
Just figured maybe theres a better forum for this......wasnt able to find say, a window forum........just the same, any advice on this specialty type work would be appreciated!!
Tanks, people. |
#3 |
You can heat up taping knife(2-3") and insert it between the glass and the adhesive.
Repeat as needed. Ron |
#4 |
double glass window pane problem- |
| Display Modes | |
| Repairing a picture window & glass questions. | rosemonster | Carpentry | 2 | 12-08-2010 09:42 PM |
| Roof or window problem?? | amyk13 | Roofing/Siding | 2 | 08-08-2010 06:26 PM |
| Replacing a sliding glass door with a new window | twildey | Building & Construction | 1 | 07-22-2010 09:40 AM |
| Moisture on windows | baum | Building & Construction | 56 | 12-22-2009 06:39 PM |
| Installing vent in glass block window | jasoncw | Building & Construction | 6 | 09-27-2009 11:57 AM |
