Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-03-2006, 11:58 AM   #1
double cylinder dead bolt
Help!! bought a house with double cylinder deadbolt on front door (key used both sides) and i can't figure out how to remove it to replace...any tips / secrets?
sleuth is offline   Reply With Quote
Old 04-06-2006, 07:46 PM   #2
Contractor
tgeb's Avatar
What brand lock set is this?
On some there are brass plugs on the inside cylinder where you would typically see screws. Take a chisel or screw driver to these plugs and pop them out. Disassemble with a screw driver as usual.
Tom
Tom
tgeb is offline   Reply With Quote
New door dead bolt and handle assembly eric s General Discussion 5 08-05-2007 06:01 PM
Deck ledger/carriage bolt question colaminecanary Building & Construction 9 07-31-2007 08:16 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Dead Battery larock5 Tools 2 06-20-2007 11:00 PM
Attach a bolt to drywall hdayanan Building & Construction 1 03-17-2006 08:01 AM
