Dormer Window Leaks - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 05:28 AM   #1
dormer window leaks
Can anyone tell me how to repair leaks around the bottom of my windows on my dormers? I had the old roof replaced but still I have leaks around the bottom of the windows. I can't seem to find anyone to that can fix the leaks. I think the windows were installed incorrectly when the house was built in '96. Any suggestions.
billygne1 is offline   Reply With Quote
Old 02-06-2010, 05:59 AM   #2
You haven't posted enough information. Most likely you will need to remove the siding and reinstall. You should have flashing tape run over the window flange and then over the house wrap. Caulking will not solve your problem. What type of siding do you have? Just because the leaks show up at the bottoms of the windows doesn't mean the water is getting in at the bottom, although it may be. The water could be getting in at the sides or top and running down.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 02-06-2010, 06:33 AM   #3
What Jaro said. It is probably not a simple fix. If flashing was done incorrectly, the siding needs to be removed and the window correctly flashed and reinstalled.
Old 02-06-2010, 07:00 AM   #4
Thanks for your reply. That is my thinking also. The dormers are in an unfinished area so I can see that the water is coming in at the bottom of the widnows....the sides are dry.
Old 02-06-2010, 07:13 AM   #5
Still sounds to me like improper flashing.
Old 02-06-2010, 11:18 AM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Its always going to be a flashing issue. Caulk should never be more than cya, extra protection.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-28-2014, 04:52 AM   #7
Dormer window water leak
I have experienced the same problem and just fixed my Dormer window water leaks. I made a video for others, hopefully useful to someone. To see my youtube video search for "comeinhandynow youtube"
Check the video "How to fix Dormer window water leaks"
Coneinhandy is offline   Reply With Quote
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
