Doors - Extended Strike Plates - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 01:17 PM   #1
Rewards Points: 358
We had all new prehung doors and 1x4 casing/baseboard installed last year, and we are FINALLY wrapping up the painting. My problem is the door latches are hitting the 1x4 door casings, so I went to a building supply store (not box store) and asked for extended strike plates, they sell what I need but the problem is they are all square cornered. So he said I have to options, grind the corners down on them or chisel out the door frame to accept the square corners. Now both of those options do not sounds very appealing to me, the grinding would probably be easier though, but I am sure I could not get it to look perfect.
I tried a search on google with no luck, but is there are places the supply a rounded corner extended strike plate?
cbzdel is offline   Reply With Quote
Old 05-12-2011, 07:40 PM   #2
kwikfishron's Avatar
Rewards Points: 356
If your pre-hung doors were installed properly you would not have to extend or grind anything for the doors to work.
Post a picture of the problem.
kwikfishron is offline   Reply With Quote
Old 05-12-2011, 08:20 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I agree with Kwik. Will one of these Full Lip Strikeplates do the job for you?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-13-2011, 12:28 PM   #4
Household Handyman
Rewards Points: 1,408
I agree with Ron, the doors were not properly installed. This sounds as if you used the 1x4 casing to trim out the doors, instead of a decorative trim. Not familiar with your area, but here new pre-hung doors would come with all the proper decorative trimming. This sounds as if the casing was installed too close to the door jamb(s). Look at your application and determine if the casing were moved 1/4"-3/8" away from the door jamb with the strike plate, would this solve the problem? I can't see where extended strike plates would solve your problem as you describe. Could you post a photo or two to help here?
Old 05-13-2011, 03:27 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Before I would jump to saying something was installed wrong, I would want to see a picture. There are plenty of doors out there with extension jambs, that need extended lip strike plates. An especially thick casing would require an extended lip, particularly with a 1/2" throw latchbolt. It's not that tough to square out the corners of the recess to fit the new strike. Extended lip strikes don't usually come with radiused corners because they are usually for a custom application. Radiused latches and strikes were designed to accomodate production line templates.
Old 05-13-2011, 10:36 PM   #6
Rewards Points: 358
yes the casing is installed with to little reveal, its about 3/16" of an inch, so the door latch is hitting the casing before it gets to the striker plate. An extended (lengthened) striker plate would solve the problem because the striker would cover the casing as well. I am not going around to every door to change the reveal, that is way to much work for me to do, the strikers sound like an easy option. I can try to get a pic up here soon.
Old 05-13-2011, 10:41 PM   #7
Rewards Points: 1,002
A internet search will reveal the strikes you need.
With a sharp chisel, you could modify the strike mortice in about 30 seconds each (well, I could do it in 30 seconds, could take you 45 seconds or a minute). It's no big deal
Anti-wingnut is offline   Reply With Quote
Old 05-13-2011, 10:44 PM   #8
I just noticed you're in T-town. Builders Hardware in Seattle 206-281-3700 1516 15th Ave W
Old 05-13-2011, 10:47 PM   #9
I also know a great young man(and it's not me) in Tacoma who may be interested in a little work, he is presently a Super for DPI
Old 05-13-2011, 11:11 PM   #10
Rewards Points: 410
You may be trimmed out in mission style with the same thickness on both
sides butt joints instead of 45's.
I'm following the same style in my basement project , just grind the corners
like I did and be done with it ......piece of cake.
High Gear is offline   Reply With Quote
Old 05-14-2011, 08:04 AM   #11
You'll also need to know the radius of the rounded corners. They're usually 1/8, 3/16, 1/4 of an inch
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 07:00 AM
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 09:32 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 10:51 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
