Doors With 5" Lockset Hole-replacements - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 07:31 PM   #1
Question
Doors with 5" lockset hole-replacements
I have doors with 5" lockset holes. I would like to find lockset that would fit without changing the doors. Any ideas or website where I could find some that fit thanks.
twhome is offline   Reply With Quote
Old 12-28-2009, 07:33 PM   #2
pics?
Old 12-28-2009, 07:46 PM   #3
The hole is regular size but the center of the hole to the edge of the door is 5" instead of the regular 3 1/2"
Old 12-28-2009, 08:15 PM   #4
Rewards Points: 131
http://www.amazon.com/Kwikset-3014-0.../dp/B000BC2I52
Last time I needed one I got it Home Depot
paul100 is offline   Reply With Quote
Old 12-28-2009, 08:45 PM   #5
Household Handyman
Rewards Points: 1,408
I ran into one about two years ago, I could order one through Lowe's, but found the longer latch-piece as "paul100" posted at a local builder supply store. I'd certainly try the apron stores before ordering. Maybe an ACE Hardware if there is one near you. Good Luck, David
Old 12-28-2009, 08:52 PM   #6
Smile
Thanks for all the help will look in to it tommorrow
Old 12-28-2009, 11:05 PM   #7
Try a locksmith shop, they may have some in stock. If not they should be able to order some. If they are Kwiksets, you can just change the knob and use the same latch.
lockman is offline   Reply With Quote
Old 12-29-2009, 07:47 AM   #8
are you saying your backsets are 3.5 and 5?
Old 12-29-2009, 08:01 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
3-1/2" is not a regular backset either. Standard is 2-3/8" and 2-3/4". Depending on the brand of lockset, 5" backsets should be available. Schlage and Kwikset definitely make them. 3-3/4" was made for a while, but I've not seen any in years. A local locksmith shop may be your best bet.
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 10:32 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 11:51 AM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
