Doors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-15-2007, 06:56 PM   #1
Doors
My House Is Ten Years Old And Some Of My Doors Bath And Bedroom Doors Close All The Way. I Have To Lift On The
Handle So It Will Stay Shut Any Advise On How To Line
Them Up
BOB123 is offline   Reply With Quote
Old 10-15-2007, 09:29 PM   #2
kemerick's Avatar
Rewards Points: 87
If you must lift on the handle to get them to close, the the upper hinge needs to be moved away from the door latch. The bottom one may need the same thing but I would try to just do the top one first.
First I would close the door almost all the way so it stops where you need to start lifting. Look at the door where it starts to hit. It sounds like it will only be hitting at the top to confirm.
Remove the door by unscrewing the screws that go into the door jamb. Take a chisle and remove the same distance of material by which the door is hitting.
A quick search yeildided this which shows the whole mortising process: http://www.taunton.com/finehomebuild...ge-chisel.aspx
If your screw holes are worn you may need to use longer and/or wider screws to bite into the wood a bit more so the door is solid.
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 10-16-2007, 03:35 AM   #3
jan
It sounds like the hinge screws are loose. Snug them with a screw driver before trying anything else. I usually replace the center screw on the jamb side of the top hinge with a screw long enough to penetrate the framing. The long screw provides extra support for the door and can be used to make minor adjustments to the fit of the door.
jan is offline   Reply With Quote
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 10:00 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
French Doors - Locking Dummy Levers highflyguy Building & Construction 4 10-08-2007 10:35 AM
outswing patio doors philS Building & Construction 2 07-11-2007 01:39 AM
Attic Doors cyepsen Building & Construction 3 06-24-2007 06:47 AM
