Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-12-2008, 11:46 PM   #1
Question
Doorknob repair
I wasn't sure where to post this, but we have some interior doors (6 panel), where the glass doorknobs have come out of what holds them in place on the door. The mechanism is intact and it appears the doorknob could be 'glued' back into place. What would be the best material to use to fix this? Elmers just doesn't work!
Also, some of our interior doorknobs have come loose, and over time, have actually fallen out of the doors....(my dear husband and his elderly dad installed them years ago, and neither of them were very mechanically inclined). The locking mechanisms never worked, either.
Any suggestions on the easiest way to reinstall and/or repair our glass doorknobs?
Feeling a breeze,
Debbie
luv2sipt is offline   Reply With Quote
Old 10-13-2008, 12:57 PM   #2
gravity always wins
Doorknob repair
If you mean that the glass portion of the knob has separated and come out of the metal part, the best repair is a two part epoxy. Don't get the epoxy into the threads on the ferrule of the knob, or you won't be able to get the knobs threaded back on. Also be sure that the square spindle where they thread onto is not so long that it pushes on the glass when the knob is installed. (I'm assuming that these are threaded spindles) If it is too long, you can: 1) try threading it farther into the opposing knob, 2) Purchase a shorter spindle from a locksmith or restoration supply house (make sure you get the correct thread, size), 3) hacksaw the existing spindle shorter. Make sure that the set screw in the side of the knob tightens down against the flat side of the spindle after you have the knob threaded into place. There are a lot of reasons why your locksets may not work. We'd need more specifics to give you advice.
Old 10-13-2008, 07:47 PM   #3
Doorknob repair
Feeling a breeze,
Debbie
I had the same problem...I just use silicon..Dow Corning 732...but I'm sure most silicon and caulking will work.
hellothere123 is offline   Reply With Quote
Old 10-13-2008, 10:44 PM   #4
Doorknob repair
Thanks for your quick responses! To 'Maintenance 6': Re: "If you mean that the glass portion of the knob has separated and come out of the metal part, the best repair is a two part epoxy." That is exactly what happened. I'll try the epoxy and see if that helps. Also Re: "There are a lot of reasons why your locksets may not work. We'd need more specifics to give you advice." To lock the door, you pushed up or down a little lever that was on the metal base of the doorknob. However, it never locked the door...you could still turn the doorknob and it would open.
And thank you 'Hellothere123' - I'll keep the silicon in mind as well!
Where would I find instructions (pictures would also be good!) for reinstalling doorknobs?
In 'The House of Open Doors',
Debbie
Old 10-14-2008, 07:29 AM   #5
gravity always wins
Doorknob repair
I am familiar with the style locksets you have. They are probably 1930's-1950's vintage. Unfortunately the mechanism that locks the knobs is in the latchbolt unit and is probably broken. Being that old they are long obsolete. You could try to remove the latch from the edge of the door while you have the knobs off and see if the latch can be lubricated, just in case the parts inside are not broken. Some of the latchbolt units could be taken apart and springs replaced, which may fix them. Others were made of white metal and riveted together, so nothing could be done with them. Fortunately, these did not require any large or special holes through the door, so redrilling the doors for new style locksets is an option.
Old 10-14-2008, 11:14 PM   #6
Doorknob repair
The doorknobs are actually "pseudo-vintage" doorknobs, as my husband and his dad bought them about 15 yrs ago from the hardware store. It may be that something was damaged when being installed, as the doors would never lock. Your advice is appreciated, however, as we need to get this taken care of soon! The Holidays are approaching and company will be coming!
Thanks again,
Debbie
Old 10-15-2008, 07:21 AM   #7
gravity always wins
Doorknob repair
If you look at the edge of the door, is there a name on the face plate where the latch bolt protrudes? Also, do the knobs thread on to a square shaft?
Old 10-15-2008, 05:36 PM   #8
Custom Cabinet Maker
Doorknob repair
try this if all else fails; WWW.VANDYKES.COM Tons of restoration hardware
skymaster is offline   Reply With Quote
Old 10-17-2008, 10:10 PM   #9
Doorknob repair
Yes, but I had to remove the faceplate to see the name, which was on the inside: "Gainsborough Hardware IND" and on the opposite end: " Ltd Australia".
And yes, the knobs do thread onto a square shaft.
Old 10-17-2008, 10:19 PM   #10
Doorknob repair
This looks like a great resource! I will definitely check this out!
Thanks!!
Debbie
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Reasonable Charge for Hardwood Repair? (pic) duffeymt Flooring 14 10-07-2008 12:51 AM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 06:49 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing 3 06-23-2007 02:02 AM
