Doorbell - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 11:19 AM   #1
Doorbell
I am having problems with my doorbell (not a personal problem ). The old doorbell broke a few years ago so I put up a new one. The problem is, it will only do a partial ring when somebody pushes and releases the switch (it will ding, but not dong). Actually, it will only give a partial chirp. If they hold the switch in, it will do the full ding-dong... but nobody seems to ever do that. I don't recall having this problem with the bell that broke.
I tried putting a new switch in to see if that made a difference... but it was the same. I thought I saw a switch a few years ago that had some sort of electronics in it. I am wondering if there is such a switch that will keep the circuit until the full cycle is done. Is there such a thing? I looked at different bells, but they all seem pretty much the same.
Is there any way I can get a ding-dong?
DIY_JC is offline   Reply With Quote
Old 05-30-2009, 01:11 PM   #2
Rewards Points: 5,336
When you changed the chime mechanism, did you check that the old transformer matched the new chime?
Ron
Old 05-30-2009, 02:42 PM   #3
yes, I believe I did. I don't recall if it was 12v or 16v. I could check again....
Old 05-30-2009, 05:17 PM   #4
Gunk/dust/oil on the solenoid armature that gives the ding and the dong?
Armature up = ding, down = dong.
Doorbell Diode hindelicato Electrical 15 10-30-2010 11:52 PM
Installed doorbell - chiming not right proofer Electrical 3 07-08-2008 04:04 PM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 01:53 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 11:12 PM
