Door Trim Not Lying Flush To Frame - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-31-2009, 11:14 AM   #1
Rewards Points: 81
door trim not lying flush to frame
Hi again, sorry to be a pain. Looks like my door frame wasn't centered correctly and now when i put the door trim on there is a 1/4" gap on one side. It is about the top 1/3 of the door and slowly tapers to flush in the middle. Here is a pic. to show you. What can i do about this? Just caulk?
mayhem69 is offline   Reply With Quote
Old 12-31-2009, 01:32 PM   #2
Rewards Points: 5,336
Caulking that width would be tacky. Measure and cut a tapered wedge to insert into the gap. If need be, caulk the remaining gap if one exists.
Ron
Old 12-31-2009, 01:36 PM   #3
Remodeling Contractor
make a piece of clear pine on a table saw o match the widest gap. Glue this flush with the side face of the jam along the edge that needs padding. After the glue cures use a planner or sander to taper the wood perfectly flush with the drywall.
Old 12-31-2009, 03:01 PM   #4
Rewards Points: 81
Now i realize what is wrong, the frame is not properly centered. My builder really is bad, does real shoddy work.
Old 12-31-2009, 09:32 PM   #5
firehawkmph's Avatar
Rewards Points: 1,826
Mayhem,
If, and I repeat IF the wall is plumb and not out of whack, you may be able to fix the door. Take the door hinge pins out and remove the door. Using a squeeze grip clamp, place it across both pieces of molding, even if the one side isn't nailed in yet. If the builder was this sloppy putting the door up, he probably didn't shim it much if at all. The door may move easily. Once you move it over, use some 2 1/2" finish nails through the jamb to hold it in place. If it doesn't move, I would remove the molding already up and cut the nails with a sawzall and rehang the door.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 03:23 PM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 08:17 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 11:03 AM
Window frame not flush with finished wall Stubbie Carpentry 9 06-24-2008 03:38 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
