Door Knob Installation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 09:00 AM   #1
Door knob installation
can someone tell me how to get a kwikset door knob with internal screws to lock together? It keeps pulling apart, looks like once you align the two sides up with all the internal mechanisms there should be away to turn it to get the two screws to lock into place. Of course you cant see what you are doing at that point.
skm123 is offline   Reply With Quote
Old 02-04-2010, 09:03 AM   #2
Rewards Points: 5,336
Go to the Kwikset website and download the instructions.
Ron
Old 02-04-2010, 09:25 AM   #3
Thanks, that was the first thing I tried, searched all over but couldn't find any instructions for that style.
Old 02-04-2010, 10:00 AM   #4
The internal mechanisms would be used on many finishes and styles. Look for one with the same escutcheon plate.
Generally with the ones with the plates with no visible screws, the plate would pop off so you could tighten the mechanism. You would release the knob with either a pin or a screwdriver, depending on the type of slot/hole was in the shaft under the knob. Then the escutcheon plate would come of, freeing you to install the screw plates on each side. Once this was done the plate would be installed over the screw plate and the knob would be aligned on the shaft and slid down until the knob dropped into it's release mechanism.
Ron
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 12:15 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
