Door Knob Help Needed = Cannot Seem To Remove It - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 04:23 PM   #1
Door knob Help Needed = Cannot Seem to Remove it
I cannot remove the door knob from the door. It is so loose that it's hard to turn the knob successfully. I can't remove it though to put a new one on.
Kate Louise is offline   Reply With Quote
Old 10-31-2012, 04:44 PM   #2
Experienced
Jackofall1's Avatar
Hello Kate and welcome the best darn DIY'r site on the web.
Sometimes a picture is worth a thousand words, and I think this is one of those times to post a picture.
Have you loosened the screws and just can't get it apart? A bit more explanation goes along way.
Mark
Old 10-31-2012, 05:58 PM   #3
Rewards Points: 13,296
There only held on one of two ways.
A set screw in the handle, it there's a rectanguler shaped or round hole that you just use a tiny screw driver to push in and reliece the spring loaded catch.
Old 10-31-2012, 10:42 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
could have a little slot somewhere on the ring that covers the door mechanisms, a little flat screwdriver slid into the slot can pop off the ring to give access to the inside of the handle where there may be a screw that needs tightening. the slot in the ring is right against where the metal touches the door...
hand drive is offline   Reply With Quote
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 10:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 11:45 PM
Remove old light fixture (hanging) dj928 Electrical 9 12-02-2009 12:42 PM
What size header is needed.... mulhollendm Building & Construction 2 11-18-2009 03:34 PM
How to remove Built-in Electric Fireplace Almighty Building & Construction 1 11-12-2009 06:18 PM
