Door From Inside House To Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 01:06 PM   #1
Door from inside house to garage
Hello! First off, thank you for your time and help!
Here's what I have... a hallway leading to the garage. At the end of the hallway there are 3 doors, one straight ahead, and one on either side. Two bedrooms on the sides, open into the bedrooms, and the door straight ahead opens into the garage.
For that garage door, I want it to be cheap, have a deadbolt hole, and be a decent insulator. Basically, I need an outswing exterior door, but I don't have the money to special order one.
So, given my situation, could I simply purchase an inswing, turn around the bottom plate, and install it backwards? I realize that it's less secure, but security isn't as big of an issue as insulation.
Thanks!
zrooster99 is offline   Reply With Quote
Old 02-19-2010, 02:41 PM   #2
Rewards Points: 5,336
First and formost, the door needs to be a fire rated door. You would need to check with your local Building Dept if the door could open into the garage.
Ron
Old 02-19-2010, 03:05 PM   #3
Rewards Points: 1,016
It needs to be a fire rated door for safety - especially so if you have bedrooms adjacent.
I have never had a bulding inspection question regarding in-swing or out-swing for a garage door, with most swinging into the garage - but as always, your area may have differing or specific requirements. A call to your building department would likely and easily provide the definitive answer.
I would make sure this is done correctly and with the proper door, as it's a common thing to be checked during a house inspection when selling/buying - and for safety.
Old 02-19-2010, 03:19 PM   #4
Fire rated... I've definitely got to look into that!
What would be involved in taking an inswing and turning it around?
Old 02-19-2010, 05:47 PM   #5
Household Handyman
Rewards Points: 1,408
It sounds like you are wanting to use an interior door for an exterior door. And do a lot of work to make an interior door work. You want low cost (not cheap), a deadbolt hole, and some insulation value. Sorry, but IMO, an interior door will not meet these requirements. As posted-you may have local code issues to meet as far as an exterior door. Being it sounds as if you already have an existing door/door frame--Is there a local "Habitat For Humanity", "Goodwill Builders Outlet", or such near? Sometimes these type places get Builders Supply businesses leftovers/overstocks which are brand new. You may find a "door slab" there to fit your needs. David
Old 02-19-2010, 05:52 PM   #6
metal door probably your best choice cost wise and habitat good place to start looking
The older I get the better I was
Old 02-19-2010, 09:39 PM   #7
jlhaslip's Avatar
Rewards Points: 1,014
We also need a spring loaded closer on those garage doors leading to the interior.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 02-20-2010, 12:43 PM   #8
What if I take an inswing door and turn it around... would there be anything wrong with that, and what would be involved in that?
Old 02-20-2010, 12:49 PM   #9
jlhaslip's Avatar
the threshold would be draining into the house and the door could be removed by popping the hinges, but it would work.
electricity from house to garage J MAC Electrical 19 07-05-2009 07:19 PM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 01:23 PM
house wrap on inside out - what to do? Knucklez Building & Construction 6 08-19-2008 11:07 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 05:44 AM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
