Door Hinge Coming Loose From Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 08:48 PM   #1
Rewards Points: 31
Door hinge coming loose from wall
My front door is coming loose from the hinge on the wall. I'm looking for a simple solution because I really don't feel like replacing the jam. Also, is there something better than putting a longer and larger diameter screw in? Thanks for the help.
GRFagan is offline   Reply With Quote
Old 01-24-2011, 09:09 PM   #2
Experienced
Jackofall1's Avatar
You could drill a hole, sized for say 3/8" doweling, insert dowel with glue, let dry, and then rescrew hinge.
Old 01-24-2011, 09:16 PM   #3
Rewards Points: 31
I like your suggestion, I hadn't thought of it.
Old 01-24-2011, 10:46 PM   #4
Old School
Willie T's Avatar
That is, by far, the easiest and best way to make the repair. Much better than simply pounding a golf "T" or sliver of wood in the hole. Also, consider using a good hardwood dowel. It will hold a lot better than something like pine or fir.
Willie T
Old 01-25-2011, 08:30 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 358
Ayuh,... Or pack the hole tight with toothpicks, 'n glue...
Let it set-up dry, redrill, 'n put yer screws back in...
Old 01-27-2011, 11:16 AM   #6
Rewards Points: 1,418
You want screws about 2-1/2 inches or maybe 3 inches, long enough to go all the way through the door jamb and into the stud deeper in.
Old 01-27-2011, 12:54 PM   #7
Rewards Points: 5,336
Drill a pilot hole.
Ron
Old 01-27-2011, 12:56 PM   #8
This only works with the holes set deeper into the jamb. The others just hit sheetrock or plaster.
Ron
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Fixing leaking shower head...turns out pipe coming out of wall is the source plumbingboy9317 Plumbing 5 05-25-2009 02:41 PM
screws coming loose Baffeled Building & Construction 4 08-13-2008 09:48 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
