Door Hinge - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 10:41 AM   #1
Rewards Points: 480
door hinge
in addition to a question i posted this morning on the carpentry board about dealing with a gap where a stud and column meet, i have a question about hanging a door.
from the directions
"surface mounted hinges can be screwed into the
frame of the door. Most hinges can
be accommodated by simply
routing or mounting with screws."
the hinge that came with the door looks like this
surface mounting seems quicker..what is the best method to use?
joetab24 is offline   Reply With Quote
Old 05-08-2010, 11:31 AM   #2
Old School
Willie T's Avatar
This is easy to answer. How are all the rest of your doors done?
Willie T
Old 05-08-2010, 11:38 AM   #3
Rewards Points: 480
in the house, they are recessed
Old 05-08-2010, 11:52 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Question
Joe, The hinge you show is for a cabinet door.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-08-2010, 11:56 AM   #5
Rewards Points: 480
i just pulled a google image that i thought looked similar. i will post the actual hinge in a few mins.
here it is.
Old 05-08-2010, 02:19 PM   #6
Tool Geek
PaliBob's Avatar
Unhappy
Originally Posted by joetab24 View Post
i.......what is the best method to use?
The reasons that the other door hinges in your house are NOT surface mounted are aesthetics and privacy.
There would be a permanent gap as wide as the folded hinge on one side of the door.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-08-2010, 03:12 PM   #7
Rewards Points: 480
what would you use for a screened porch door, surface mounted or recessed?
Old 05-10-2010, 01:27 PM   #8
Rewards Points: 480
have never recessed a door hinge. What's the best way to approach this? Should i use a router and a template?
Old 05-10-2010, 07:37 PM   #9
Tool Geek
PaliBob's Avatar
Old time carpenters did not have a router, they just used a chisel to mortise the hinges into the door and into the jamb.
Most screen doors are now aluminum that have factory mounted thin steel hinges that are most commonly surface mounted to a wooden door jamb.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-10-2010, 09:52 PM   #10
Rewards Points: 480
should have mentioned this from the start. i have a vinyl door.
i dropped my chisels off at a local guy who sharpens tools.
maybe a stupid question, but can i recess a hinge on a vinyl door?
