Door Frame Not Flush With Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-31-2009, 03:37 PM   #1
door frame not flush with drywall
I have seen many people with the drywall sticking past the door but i have the opposite problem. My door frame is about 1/8" - 1/4" past the drywall. What can I do so that I can install the trim? Please help!!!
ppman is offline   Reply With Quote
Old 12-31-2009, 04:14 PM   #2
Jack of all, master nope
Is this a new installation meaning drywall, studs, and I assume a pre-hung door? What is the clearance on the other side of the door? Is it flush with the drywall?
rss021815 is offline   Reply With Quote
Old 12-31-2009, 04:57 PM   #3
DIY staff
Rewards Points: 7,174
If resizing the jambs is not an option for you, consider a 'Trim extender'.
A thin slice of wood tucked under the outside edge of your casing and nailed in with the trim.
Not ideal,but most people will never notice---MIKE--
Old 12-31-2009, 05:47 PM   #4
Old School
Willie T's Avatar
This is a gross exaggeration of what can happen if the installer does not ensure that the HINGE side of the door jamb is SQUARE (perpendicular) with the wall.
This occurs because the out-of-square hinge jamb causes "hinge bind" when the door is shut... (The door 'bounces' and springs open a little when shut)... so the installer moves the latch side of the jamb around to compensate, and get the door to shut correctly.
Well, the door SEEMS to shut right, but the jamb often manages to become misaligned with the opening. Many times, this goes unnoticed until you try to install the trim.
This is just one scenario... but it is more common than you might think.
The door on the right is installed correctly. The one on the left is crooked because the hinge side (the one closest to you in the drawing) is not flat and square with the wall edge.
The second drawing shows the same door from the other side.
door frame not flush with drywall-door-frame.jpg   door frame not flush with drywall-door-frame-2.jpg
Willie T
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
BackerBoard not flush with drywall at seam. Request Solutions Mitch3GP Drywall & Plaster 3 09-28-2009 12:59 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
