Door Cracking Around Lock - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 09:02 AM   #1
Door cracking around lock
I had a pre-hung external door installed on the 21st. about 1 week later I noticed cracking around the lock area.
Is this normal? what is the cause of this typically?
I have a one year warranty on the door install, and a longer one on the door itself (I think 15 years). so I will be calling the installation company I just want to have an idea of what caused this before talking to him.
Note all the install was done by them, including the hardware (handle and deadbolt). but the hardware was provided by me (via Canadiantire).
Howie!
hswerdfe is offline   Reply With Quote
Old 11-30-2012, 09:19 AM   #2
Too Short? Cut it Again!
This is not at all normal and compromises what you hoped to gain with the high security lock! It looks like something is not lining up or they crammed the thing into an improper opening. Make them fix it.
The Following 2 Users Say Thank You to user1007 For This Useful Post:
hswerdfe (11-30-2012), ToolSeeker (11-30-2012)
Old 11-30-2012, 09:23 AM   #3
Rewards Points: 14,306
Bet it happened when they were using a chisle to cut in the mortis for the latch bolt.
Old 11-30-2012, 09:42 AM   #4
joed's Avatar
Rewards Points: 13,734
Looks like the hole was too small OR someone tried to kick the door open and broke it. Are there any footprints on the outside of the door?
The Following User Says Thank You to joed For This Useful Post:
Old 11-30-2012, 11:57 AM   #5
Thanks everybody, I guess it was likely an issue with the install, and not the door.
sdsester: I will be insisting the honor their warranty.
joed: Their are no other visible signs of an attempt at forced entry.
Old 11-30-2012, 11:45 PM   #6
Brinks is hardly a high security hardware by any means.
The damage was done when they used a chisel to cut the vertical cuts to mortise the edge of the door. I've seen it hundreds of times and can almost assure you that the damage is only as deep as the mortise and does not compromise your security of your metal door at all.
It is a poor installation job though.
spotco2 is offline   Reply With Quote
Old 12-01-2012, 06:40 AM   #7
Rewards Points: 2,240
Just because there are "no signs" of a forced entry -
does not mean, it was not attempted!
It does look like the the plate on the latch is a little too, wide, though!
"RF"
rossfingal is offline   Reply With Quote
Old 12-01-2012, 06:52 AM   #8
kwikfishron's Avatar
Rewards Points: 1,004
Just seeing pencil marks shows the lack of experience of the installer.
kwikfishron is online now   Reply With Quote
Old 12-01-2012, 07:15 AM   #9
Rewards Points: 2,648
But look at the side that is most damaged. That would be more readily explained by somebody kicking the door from the inside.
SPS-1 is offline   Reply With Quote
Old 12-01-2012, 07:31 AM   #10
Come on guys, pencil marks on the side, rough edge on the sides. The recess was just not wide enough and someone used a chisle to widen it and just taped a little to hard and split it.
There's cracks on three sides not just one side.
No one's mortised a lock set by hand and not seen this before?
Old 12-02-2012, 07:36 AM   #11
I just looked at the one I did about a year ago and guess what? Same type of thing there also. I do remember 'tapping' with rubber hammer to make it fit........
Mine was tight for a month or so then perfect. Guess I should go back and fill in the areas where the chisel was not perfect? Nope...
pinkfloyd43 is offline   Reply With Quote
Antique mortise door lock repair (possibly deadbolt problem?) ohman Windows and Doors 14 08-18-2015 09:58 PM
Failing to understand pocket door lock catapult37 Windows and Doors 4 08-11-2012 12:05 PM
key in the lock on the inside and now can't open from outside kwisj Windows and Doors 1 05-18-2012 07:37 AM
Front door lock gets stuck injvstice Windows and Doors 13 03-22-2012 12:31 PM
Lock part for Vintage Schlage privacy lock? JustMe00 Carpentry 2 09-14-2011 07:14 AM
