-   -   Door cracking around lock (http://www.diychatroom.com/f2/door-cracking-around-lock-165153/)
hswerdfe 11-30-2012 10:02 AM
2 Attachment(s)
I had a pre-hung external door installed on the 21st. about 1 week later I noticed cracking around the lock area.
Is this normal? what is the cause of this typically?
I have a one year warranty on the door install, and a longer one on the door itself (I think 15 years). so I will be calling the installation company I just want to have an idea of what caused this before talking to him.
Note all the install was done by them, including the hardware (handle and deadbolt). but the hardware was provided by me (via Canadiantire).
Howie!
Attachment 61229
Attachment 61230
user1007 11-30-2012 10:19 AM
This is not at all normal and compromises what you hoped to gain with the high security lock! It looks like something is not lining up or they crammed the thing into an improper opening. Make them fix it.
joecaption 11-30-2012 10:23 AM
Bet it happened when they were using a chisle to cut in the mortis for the latch bolt.
joed 11-30-2012 10:42 AM
Looks like the hole was too small OR someone tried to kick the door open and broke it. Are there any footprints on the outside of the door?
hswerdfe 11-30-2012 12:57 PM
Thanks everybody, I guess it was likely an issue with the install, and not the door.
sdsester: I will be insisting the honor their warranty.
joed: Their are no other visible signs of an attempt at forced entry.
spotco2 12-01-2012 12:45 AM
Brinks is hardly a high security hardware by any means.
The damage was done when they used a chisel to cut the vertical cuts to mortise the edge of the door. I've seen it hundreds of times and can almost assure you that the damage is only as deep as the mortise and does not compromise your security of your metal door at all.
It is a poor installation job though.
rossfingal 12-01-2012 07:40 AM
Just because there are "no signs" of a forced entry -
does not mean, it was not attempted!
It does look like the the plate on the latch is a little too, wide, though!
"RF"
kwikfishron 12-01-2012 07:52 AM
199 Attachment(s)
Just seeing pencil marks shows the lack of experience of the installer.
SPS-1 12-01-2012 08:15 AM
But look at the side that is most damaged. That would be more readily explained by somebody kicking the door from the inside.
joecaption 12-01-2012 08:31 AM
Come on guys, pencil marks on the side, rough edge on the sides. The recess was just not wide enough and someone used a chisle to widen it and just taped a little to hard and split it.
There's cracks on three sides not just one side.
No one's mortised a lock set by hand and not seen this before?
pinkfloyd43 12-02-2012 08:36 AM
I just looked at the one I did about a year ago and guess what? Same type of thing there also. I do remember 'tapping' with rubber hammer to make it fit........
Mine was tight for a month or so then perfect. Guess I should go back and fill in the areas where the chisel was not perfect? Nope...
