Door Bottom (sweep) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 01:54 PM   #1
Rewards Points: 590
Door bottom (sweep)
Does anyone know of a good replacement bottom for a wooden door? I mean the vinyl fins that attach to the bottom, not a sweep "blade" that attaches to one side.* The bottom on my door was falling apart where it meets the door frame on the latch side. I replaced it with a L-shaped bottom (Thermwell aka Frost King) that screws down on one side, which is fine but the fins are so long that they made the door hard to operate and most tore off within a few weeks. The intent was not to have to take the door off the hinges (I have no storm, so we'd be open to the elements while I work), but if I got one that tacks to the bottom like the original I'll go for it... if I could find one.
* See, a sweep makes no sense because it attaches to the inswing side of the door, which means it isn't closing the gap on the outside of the door where the seal is.
operagost is offline   Reply With Quote
Old 12-02-2010, 09:21 PM   #2
Rewards Points: 2,630
If you go to any of the big box stores you should find a wide variety of door sweeps. If you previously had a brush style that mounts to one side, I don't think that is going to be effective.
You should be able to find something like this, which is more solid and wraps around the bottom of the door. Measure your door thickness before you drive to the store. Note that the mounting holes are slotted. When you put the screws in, make sure you have room so you can raise or lower the sweep so that it is just touching the floor.
The multi-blade style worked well for me, but there are many styles, and you need to think about what will work best for the door and frame you have.
SPS-1 is offline   Reply With Quote
Old 12-02-2010, 09:24 PM   #3
photo didn't make it first time. I meant to post this:
Old 12-02-2010, 09:52 PM   #4
Rewards Points: 6,652
If the bottom edge of the door is falling apart, no sweep will stay on very long, even if you trim the sweep for length of the door. What you may have to do, is just bite the bullet, and replace the door and frame with a good steel or fiberglass insulated door.
Old 12-03-2010, 12:44 AM   #5
Rewards Points: 590
The door itself is in good condition; it's the rubber door bottom that wasn't.
Those U-shaped ones have exactly the same length fins and won't make as good a seal because of the extra plastic on the outside. I already tried an aluminum one and a new gap was created where the kerf seal met the metal.
Old 12-03-2010, 12:19 PM   #6
Rewards Points: 5,336
I'd put a storm door on and any seal that kept the wind out on the main door.
Ron
Old 12-06-2010, 11:26 AM   #7
Rewards Points: 590
This what I was looking for. I finally determined the magic Google words :-)
http://www.allaboutdoors.com/product...ducts_id=84006
Tough time to have the house open, though, so I'll either need to hang plastic while I'm doing this or just rig up something for now.
New prehung door threshold too tight against sweep dwoloz Remodeling 11 11-27-2012 11:23 AM
Long sweep 45 degree elbows wtroger HVAC 5 09-22-2009 01:46 PM
Can this door sweep be used vertically? abefroman Remodeling 2 08-06-2009 01:36 PM
door sweep gets carpet wet? darsunt Carpentry 13 08-22-2007 01:08 AM
